Old 11-09-2017, 10:12 PM   #451
Dohsh77
Drives: Yaris
I need ecu part number for yaris sedan1300 cc ATM old shap
That support cruise control
Dohsh77 is offline   Reply With Quote
Old 11-10-2017, 03:50 PM   #452
weltall900
Drives: 2007 Toyota Yaris
My apologies if this has been asked before. I'm going to attempt this project for my wife's car. I'm not super mechanical, but I'm going to try my best and pray that I don't mess up her car! She has a 2007 Yaris with automatic transmission. I'm wanting to use the OEM stalk setup and I've read through much of this thread and the 2006-2011 Yaris – OEM Cruise Control Installation PDF. However, I'm not sure if her car is Sedan with power OR Sedan without power. Not even sure what that means. She has power locks, power windows, manual seats, automatic transmission, manual side view mirrors, and obviously no cruise control. I included an image from the guide here. Which applies to me? The one I circled in RED or the one I circled in BLUE
weltall900 is offline   Reply With Quote
Old 03-14-2018, 06:28 AM   #453
Dohsh77
Drives: Yaris
Originally Posted by ricepower View Post
Moderators, pls have this thread sticky! please ...
All this ecu p/n for 1nz engine 1500cc. Any ecu p/n for 2nz 1300 cc
Old 03-14-2018, 06:28 AM   #454
Dohsh77
Drives: Yaris
Old 04-29-2018, 04:24 PM   #455
DanielNorrisII@Gmail.com
2007 Toyota Yaris with Blue and Brown Wire in D3
I have a 2007 Toyota Yaris with Blue and Brown Wire in D3 no A21 pin 40. What am I supposed to do with wire coming from ECM A21 pin 40?
DanielNorrisII@Gmail.com is offline   Reply With Quote
Old 04-29-2018, 04:30 PM   #456
Also, where can I get a Cruise Control Indicator Module? Does CTScott still have some available or is their a wiring diagram that I could build one myself?
Old 04-29-2018, 05:18 PM   #457
Ok, I looked up the electrical drawings for cruise control. D3 goes to AD4, which is a connection between harnesses, and on the other side of the harness connection their is no wire coming out to pin 40 on A21. I got extra repair terminals, so I will put a terminal in the empty side going to pin 40 and solder it to the repair terminal I install in pin 40.
Old 05-13-2018, 08:35 AM   #458
Prakersa
Drives: Yaris
Can you share the diagram of CC. Still curious for the AD4 location... Tks
Prakersa is offline   Reply With Quote
Old 05-20-2018, 11:35 AM   #459
laobo
Drives: yaris sedan 2011
who said me know
dear!
w/power and w/out power means?
different?
laobo is offline   Reply With Quote
Old 09-24-2019, 02:12 PM   #460
giorgos01
Drives: toyota yaris 06 1.3
ABOUT MY YARIS 2006 CRUISE CONTROL
HI CTScott
15 days ago i bought a 2006 gasoline 1.3 i really want to install cc and i would like your help, the car is european and my ecm number is
89661-0D310
https://photos.app.goo.gl/qqk757aZasRFupdj7
giorgos01 is offline   Reply With Quote
Old 09-25-2019, 12:32 PM   #461
rebelluck
Drives: 2015 Toyota Yaris L
Does my american 2015 Yaris L have prewired cruise control? Hoping for just a plug and play here.
rebelluck is offline   Reply With Quote
Old 09-26-2019, 01:47 AM   #462
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
It should just be a matter of mounting and plugging in the control stalk.
Have a look at http://yarisworld.com/forums/showthread.php?t=37205
The 2015 should only be a facelift from 2012.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 04-09-2020, 01:06 PM   #463
reg_account
Drives: 2010 sedan
Hoping this thread is still alive. I am about to buy a base model 2010 4 door sedan without power locks/windows and auto transmission. Does this require just the stalk and wire? The guide seems to say it requires running wires to the ECM but a few posts here have confused me if that is needed. Since I don't have the car yet, I can't look but I wanted to get the parts.
reg_account is offline   Reply With Quote
Old 07-19-2020, 11:53 PM   #464
bluefever00
Drives: 2008 Sedan
Quick question, would my 2008 Sedan automatic require the d3 pins? I don't have power windows/locks/mirrors if that makes a difference.
bluefever00 is offline   Reply With Quote
Old 09-09-2022, 11:05 AM   #465
OCEANROADS
Drives: 2010 Yaris
My gf has a 2010 Yaris with a stick.
I installed a cruise control stalk I bought online. The dash light comes on showing cruise control is on, but it will not engage?
Do I need to add the clutch sensor?
Can someone please repost the clutch sensor wiring instructions?
OCEANROADS is offline   Reply With Quote
Old 09-09-2022, 08:11 PM   #466
sh0rtlife
yes you have to add the clutch switch, without it..the cruise acts like the clutch is stuck in...and just wont do anything
as for the wiring..a lil searching and you should find it
Old 09-12-2022, 01:58 PM   #467
thetut
Drives: 2007 4dr sedan
Read the last post here: https://www.yarisworld.com/forums/sh...t=33750&page=9
thetut is offline   Reply With Quote
Old 10-18-2022, 10:20 AM   #468
Xuanbinhktv
Drives: Toyota Vios 2011 MT
Hi every one!
I'm fom Viet Nam , my car is toyota yaris/vios 2011 Mt, Asia production, can I install cruise control for my car? thanks alot!
Xuanbinhktv is offline   Reply With Quote
