Old 01-02-2015, 11:11 PM   #1
LSandulak
LSandulak's Avatar
Drives: 2008 Toyota Yaris
Fan control knob light is out.
Hi,
2008 Toyota Yaris HB RS. The light that illuminates the fan control knob is out. Can some one explain how to replace the bulb? Please and Thanks.
LSandulak is offline   Reply With Quote
Old 01-02-2015, 11:26 PM   #2
If you search a bit on here there are a couple of threads that show what the bulb looks like and how to replace it.
Old 01-05-2015, 12:32 PM   #3
shepd
Drives: 2007 Yaris 5 door RS
Handy thread with pictures:
http://www.yarisworld.com/forums/showthread.php?t=44520
Removing the knobs:
http://www.yarisworld.com/forums/sho...light=led+dash
Took longer than I wanted it to take because the bulbs are not easy to get seated. The part will cost about $13. Stock bulbs are actual (miniature) light bulbs, not LEDs.
FWIW, you do not have to remove the radio itself, however, the bezel around the radio is in the way of getting climate controls out so I'd remove it.
shepd is offline   Reply With Quote
Old 01-05-2015, 01:16 PM   #4
nookandcrannycar
On my '07, the bulb went out. I bought a new bulb. Before I had a chance to install it, the bulb started working again...with no issues since. I returned the bulb.
Old 01-05-2015, 03:12 PM   #5
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
The same thing happened to one of my clearance lamps.
Over a time of about 4 months, it died 3 times and lit up again when slightly struck.
As it died finally, I was lucky to have a multimeter under my seat (I can only recommend to do so!).
I suspected a wire to be broken, but it was the lamp.
2€ for 2 new ones, and I was done.
I drive, therefore I am.
dj92 is offline   Reply With Quote
Old 01-05-2015, 03:44 PM   #6
LSandulak
LSandulak's Avatar
Thanks everyone for the info and help. CTScott sent me this link as well http://www.yarisworld.com/forums/showthread.php?t=44520.
Thanks again.
Engine light + loss of throttle control travishv DIY / Maintenance / Service 1 06-20-2014 06:09 AM
DIY Cruise Control for 2012 European made Yaris CTScott DIY / Maintenance / Service 1 12-27-2011 06:47 AM
Looking for 2007-2008 Fan control console knob detroiter Willing to Buy by private party 0 08-04-2010 10:19 PM
Classic shift knob from TWM Performance now available with engraved shift patterns! TWM Performance TWM Performance 0 07-21-2009 10:57 AM
