Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 01-11-2010, 12:22 PM   #19
Stiv
Drives: Yaris TS 1,8L
Great, thanks mate. That's the information I was missing.
So now we wait for a lovely sunny day for me to get my hands dirty in the engine bay :)
I'll keep you all posted
Stiv is offline   Reply With Quote
Old 01-11-2010, 12:34 PM   #20
127.0.0.1
Drives: '10 Yaris5drHB+99 4runner LTD
Got it. I was thinking that quick press was VSC off, not TRAC off.
OK, so in that case, as long as one does the long press with the switch, there are no worries about TRAC being re-enabled on acceleration.
TRAC, if turned off by the mild button press, will reactivate automatically
VSC, if turned off by the hard button press, will NOT reactivate automatically
TRAC, if turned off by the feet and handbrake, will NOT reactivate automatically
that is what techinfo.toyota.com sez about 2010 yaris
127.0.0.1 is offline   Reply With Quote
Old 01-11-2010, 12:37 PM   #21
Sounds good. You owe us some pictures of your Yaris as well. I enjoy seeing them in their native habitats all over the world.
Old 01-11-2010, 01:10 PM   #22
knowmercy
knowmercy's Avatar
Drives: Blk 3door
Makes me curious about the 2009 Yaris models.... going to have to do some research.
knowmercy is offline   Reply With Quote
Old 01-11-2010, 01:14 PM   #23
For US Yaris, VSC and TRAC weren't available in 2009.
Old 01-11-2010, 02:10 PM   #24
DerFlosser
DerFlosser's Avatar
Drives: Yaris
DerFlosser is offline   Reply With Quote
Old 01-11-2010, 03:31 PM   #25
yaris2010RS
yaris2010RS's Avatar
so if u were to dissable VSC and TRAC (i have the switch, so i know the long hold) they will never turn on again unless the car is restarted or the switch is depressed again. and the car has no other traction control functions. i'm looking to drift and such but found with only TRAC off the independent braking still was applied (since i found out about the long hold for VSC it hasn't snowed again so haven't been able to test it)
Old 01-11-2010, 04:39 PM   #26
127.0.0.1
so TRAC doesn't come back on by itself, as vehicle speed increases...if you previously disabled only TRAC and not disabled VSC also ?
techinfo says trac will come back on, if only trac was turned off
Old 01-13-2010, 03:55 AM   #27
Stiv
Ok, so I took a look at the brake actuator yesterday, a found that it's quite accessible. But it was late last night and I wasn't feel like taking out the battery. The connector really looks like A30 (quite big and without round corners like A15).
I'll try to do that dirty test with a wire during this weekend.
Old 02-02-2010, 01:00 PM   #28
Kongo-Otto
Drives: '09 Yaris & '10 Auris
Is it possible for someone who got the switch from factory to make a picture of its back? I found some connectors under my handbrake lever and want to know if maybe i can attach the TRC/VSC switch to one of them.
Old 02-02-2010, 01:13 PM   #29
Here's what the 2010 service manual shows of the connector on the bottom of the VSC off switch:
Old 02-02-2010, 01:55 PM   #30
Kongo-Otto
Thank you but no luck for me. I found this little guy but have no clue what it is used for.
Old 02-02-2010, 02:10 PM   #31
Do you have keyless entry? That connector looks like the one for the keyless entry receiver.
Old 02-02-2010, 02:14 PM   #32
Kongo-Otto
No but maybe its prewired. "Executive" models have keyless entry here.
Cruise control install 2009 Yaris 3 door PeteZNY DIY / Maintenance / Service 125 03-31-2024 09:22 AM
DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) CTScott DIY / Maintenance / Service 217 08-11-2021 11:20 AM
DIY - Headlights off with the Ignition Switch CTScott DIY / Maintenance / Service 46 11-03-2018 08:42 PM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
replacement fog light switch? yrsdrgn Cosmetic Modifications (Exterior/Interior) 4 07-17-2007 04:11 PM
