05-21-2011, 11:37 AM | #1 |
Drives: Yaris sedan Join Date: Jun 2010
crush washer on drain plug?
Hello, Does the Yaris come with a crush washer on the drain plug from the factory? I did 2 oil changes so far on the Yaris, and a few on a 02 Corolla, guess what, both of them don't have a crush washer! Maybe the guy at the shop just tossed them away? Should i get one for my next oil change? Thanks.
05-21-2011, 11:42 AM | #2 |
Drives: '07 Yaris turbo, '11 Juke Join Date: Mar 2007
Yes, it comes with one. You can buy them for about $.50. I always replace mine at every oil change.
05-21-2011, 12:25 PM | #3 | |
JOE GIRTH
Drives: YARIS 3DOOR Join Date: Feb 2007
05-21-2011, 12:34 PM | #4 |
boydstir
thats what im thinking any leaks i know when i did the auto trans drain i tryed using the old crush washer and it dripped slightly so now i have extra drain plug and washers just in case for oil and trans
05-21-2011, 12:51 PM | #5 |
05-21-2011, 01:08 PM | #6 |
Drives: '08 LB MT Bayou Join Date: Oct 2008
Mine doesn't have one. No leaks either.
05-22-2011, 10:55 PM | #7 |
Drives: 2008 HB, A/T, Power W/L/M Join Date: Oct 2008
They tend to stick to the oil pan and not stay with the plug. I always have to tap them off the bottom of the pan with a screwdriver or wrench. They are an aluminum washer sandwiched between grey paper.
Never take eyes off opponent - Bruce Lee |
05-24-2011, 01:16 PM | #8 |
Drives: 2008 yaris, stripped, red Join Date: Jan 2009
should be included in oil filter if there's one on the car. mine has a rubber gasket i think. idk...it's only been 6 months since my last oil change
05-27-2011, 12:43 PM | #9 |
I changed my oil yesterday, and i saw there was a silver washer permanently attached onto the black oil pan. Right by the drain hole. Anyone else noticed it?
07-08-2012, 10:35 AM | #10 |
Drives: 2008 yaris Join Date: Jul 2012
mine has the same thing..was worried that there was no gasket..but that must be it.
07-08-2012, 11:39 AM | #11 |
play every day
Drives: 2012 Yaris L 2dr 5sp Join Date: Apr 2012
Same here. I did the first oil change on my 2012 and was searching the oil pan for the washer when it was stuck on the pan!
I just left it stuck there and put the plug back in. No leak. |
06-01-2023, 06:40 AM | #12 | |
Drives: toyota yaris Join Date: Jun 2023
06-01-2023, 11:06 AM | #13 |
Drives: 2007 4dr sedan Join Date: Jun 2009
Go to toyodiy.com and enter your VIN in the Parts reference page and search for GASKET(FOR OIL PAN DRAIN PLUG)
This will tell you if it should have one or not. |
06-02-2023, 01:18 PM | #14 |
Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
the drain plug gasket on the yaris from the factory is a blue felt type material gasket, it is one time use and must be replaced after every oil change, it is by far the best gasket as it does a good job to not scratch up the surface of the oil pan or drain plug itself
06-07-2023, 02:20 AM | #15 |
Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Never replaced a crush washer in my life and I've never had a come back or an oil leak on friends or family vehicles.
06-08-2023, 02:09 PM | #16 |
Drives: 2007 5dr canadian import Join Date: Dec 2016
mostly true, really depends on the last monkey who tightened it....with the exception of aluminum oil pans tending to need to have them replaced
Similar Threads | ||||
Tranny Fluid/Oil Drain Plug Questions | WankelsRevenge | DIY / Maintenance / Service | 3 | 03-08-2011 04:01 PM |
Review: Magneticdrainplug.com's magnetic drain plug | schleppy | DIY / Maintenance / Service | 13 | 04-21-2009 12:04 AM |
Oil drain plug gasket question | schleppy | DIY / Maintenance / Service | 7 | 04-17-2009 05:35 AM |
motor oil drain plug washer | xpeteyjtx | DIY / Maintenance / Service | 13 | 12-30-2008 01:27 PM |
