Old 04-24-2017, 05:59 PM   #1
rangerkeim
Drives: 2010 Toyota Yaris
Rough Idle/ Stall, Very Hard To Start, Tried usual suggestions
Ok so i am going to admit defeat and ask for help, ive tried everything ive seen on here about trying to fix the idle and nothing has worked. I have replaced the plugs and coils, cleaned the throttle body, cleaned and then replaced the MAF sensor, Cleaned and replaced the air filter, replaced the battery, tried to reset the throttle position using everyones suggestions on how to do it but im still having the same problems, I end up having to crank the car for 10-60seconds while pedaling the gas pedal to get it to start, while the cool light is on the engine runs fine, as soon as the cool light comes off or i drive a little bit the engine will stall as soon as it is out of gear, pressing in the clutch or sitting at a red light. The egine after it stalls is just as hard to crank over i usually end up kick starting it. I have no idea what to do, their are no codes, and no check lights, not even any permenant codes. Any suggestions or help would be greatly appreciated.
rangerkeim is offline   Reply With Quote
Old 04-24-2017, 05:59 PM   #2
rangerkeim
forgot to mention 2010 toyota yaris sedan stick shift.
Old 04-24-2017, 07:16 PM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Have you checked the fuel system?
Pull the injectors and see if there's any abnormalalities.
Can you check the afr sensor readings?
Old 04-24-2017, 08:04 PM   #4
rangerkeim
What exactly do I need to check in the fuel system? I have pulled off the fuel line and it delivers fuel while cranking, my obd doesn't have a afr listed on the live data, I havnt pulled the injectors yet but it's on the list of possibilities, problem I am having is 20 solutions to the symptoms but without a code telling me where to look into feel lost. Gonna try to post video of start up and obd2 readings. Rpms hover at 400 once warm. Not very tech savvy it seems gonna upload the videos to you tube and post link
Video 1 https://youtu.be/PPYG15p-IMA starting
Video 2 https://youtu.be/cEmcSt-J5yg obd2
Old 04-24-2017, 09:15 PM   #5
tmontague
tmontague's Avatar
does your reader show you O2 voltage? Seems like the car will work in open loop but not closed which is odd
Old 04-24-2017, 09:51 PM   #6
rangerkeim
02b1s1(v) is 3.3
Old 04-24-2017, 10:01 PM   #7
tmontague
tmontague's Avatar
Does it oscillate or is it only reading 3.3 constant?
Old 04-24-2017, 10:02 PM   #8
rangerkeim
oscillates
Old 04-24-2017, 10:05 PM   #9
rangerkeim
people have told me timing chain, injectors, fuel pump, camshaft sensor, o2 sensor, ect ect ect and i just dont know where to start, its getting expensive replacing things hoping it will do something
Old 04-24-2017, 10:16 PM   #10
rangerkeim
is it normal for the fuel pump to only pump fuel when cranking and not when the key is turned on?
Old 04-24-2017, 11:18 PM   #11
Bluevitz-rs
yes.
3.3v is running lean. It should be around 2.5V if your running regular gas.
Try unplugging the AFR sensor and see if your car runs better. If it's still the same, you'll have to check your fuel pressure with an in-line gauge you hook into the fuel line right at the fuel rail. From your description of having to crank for so long and running lean once running, it sounds like you have very low fuel pressure. The pump might have developed an internal leak or the built-in pressure regulator failed.
Old 04-25-2017, 12:04 AM   #12
rangerkeim
yes.
Any idea where the afr sensor is on this model? I've been looking for schematics online but havnt found anything
Old 04-25-2017, 04:33 AM   #13
Bluevitz-rs
It's the first sensor in the exhaust coming out of the engine.
Old 04-25-2017, 04:40 AM   #14
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
You have fuel when cranking but how much fuel? Check fuel pressure and check if it holds pressure when you turn it off. (44-50 psi idle) after 5min eng off at least 20psi pressure hold.
Your injectors could be leaking causing rough running and misfires.
You can also check the resistance of the injectors 13-14 Ohms at 20C (68F)
It gets expensinve when you are just replacing stuff. Diagnose first then replace. All the inspections are listed in the repair manuals ask for help and we can get you the information. :)
Good luck !
ncp13 is offline   Reply With Quote
Car wont start - help! tamo300 General Yaris / Vitz Discussion 14 03-23-2010 10:44 PM
Yaris does not start jake002 DIY / Maintenance / Service 21 01-05-2010 08:53 AM
Remote Engine Start PT398-33070 Reeves360 In Car Entertainment + Electronics (audio / video / alarm) 3 08-26-2009 07:11 PM
Rough engine start w/76? guyver408 DIY / Maintenance / Service 12 06-26-2009 12:18 AM
Rough Idle in drive toyoman NY / NJ/ CT / PA 8 04-22-2007 03:40 AM
