Old 04-12-2019, 06:11 PM   #19
Faulteh
Drives: 2008 Yaris Manual
Will this help me figure it out by reading values or only help if I have a check engine light on?
Faulteh is offline   Reply With Quote
Old 04-12-2019, 06:24 PM   #20
IllusionX
Drives: 07 Yaris Sedan Aero
I think you should just get rid of it, or fix it.
Get it tested. They will take an hour or so to run some tests and you'll be 150$ short so you know how low you should sell your car for.
Sent from my CLT-L04 using Tapatalk
Old 04-13-2019, 08:50 AM   #21
Faulteh
I bought a scanner and will be running through https://youtu.be/RZ_DLBQN548 to see if it is indeed a misfire.
Old 04-16-2019, 08:18 AM   #22
Faulteh
Just a follow up. I put some STP water remover in the gas and the issue is almost entirely gone. The car did sit for a couple weeks with some crazy temp swings so it may have just been condensation.
Old 04-16-2019, 08:24 AM   #23
Leegamer
Leegamer's Avatar
Drives: 2008 Yaris HB 5-Speed
That's weird. It sounds like some kind of limp mode for sure.
I'm a hermit named Lee
Old Yesterday, 07:47 PM   #24
Faulteh
Hey all!
Me again! Yep,,,, this saga continues. The issue returned and I got an odb2 scanner on the thing.
I get random cylinder misfires across all cylinders.
I checked the o2 sensors and sensor 1 bank 1 returns no data at all and sensor 1 bank 2 returns data I don't really know how to interpret.
Getting no data from Bank 1, does this suggest my O2 sensor is dead?
Old Yesterday, 07:58 PM   #25
IllusionX
There is an upstream o2 sensor and a downstream o2 sensor.
I'm not sure if you should be able to read data from both, but if it was a bad o2, I'm pretty sure you would get a code. A bad o2 would also get you into limp mode, which would prevent engine to rev as well...
Old Yesterday, 08:29 PM   #26
tmontague
tmontague's Avatar
My ultragauge receive data from both so there is something odd for sure. But why you don't have a CEL is beyond me
I like to drive a slow car fast...
tmontague is online now   Reply With Quote
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
