Old 08-30-2015, 10:06 PM   #1
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
Spark plugs, a cheap must do maintenence item
So I recall reading in our forums that the spark plugs should be fine for over 100k miles and one need not worry about it. I finally got around to changing them as I've been having hard starts and lower mpg. The difference was dramatic, no more hard starts and much smoother acceleration. I have yet to measure the mpg and will report the results of mpg in a week or two. Next maintenance items will be both oxygen sensors, transmission flush, coolant flush, and fuel filter. Will report the results of each as I move along as far as mpg and how the car "feels"
07liftback is offline   Reply With Quote
Old 08-31-2015, 06:10 AM   #2
bronsin
bronsin's Avatar
You could have regapped the plugs those gaps are pretty big.
On my motorcycles which I used mainly for long distance riding the plugs last 100,000k miles and they were regular plugs.
Consensus on this forum pretty much is transmission and coolant system flushes aren't necessary.
The fuel filter isn't considered a regular maintenance item by Toyota and my experience (20 years) with EFI is the ff only needs changing when a contamination event happens. The ones Ive changed were like new.
You might do the oxygen sensors. The ones on my cars never failed so I don't.
Not trying to start an argument just trying to save you time and $$$$.
Youre right to take the plugs out when the engine and mpg go south. But I would bet regapping the plugs would solve the problem.
How many miles on your car?
Old 08-31-2015, 09:36 AM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
So you replaced your 100,000mile plugs for 20,000mile plugs?
Old 08-31-2015, 08:58 PM   #4
07liftback
07liftback's Avatar
I'm at 105k miles currently. Just seems like we ignore most maintenance items on this forum. I mean the plugs cost $13 and took me around ten minutes to change. It looks like the plugs barely have anything left, I mean regapping them probably would've worked too but it still wouldn't spark as well as new plugs. Pretty sure the O2 sensors have also gotten lazy since my mpg has been going south for about a year or so.
The OEM plugs are made by NGK so no, they aren't 20k plugs by any means. If I wanted a long lasting plug, I would've went for the nickel plugs by NGK but these copper core plugs create a better spark although they might only last 30k-60k. During that time, they'll probably save more gas and make up for the difference in quicker plug change intervals.
Old 09-01-2015, 05:59 AM   #5
bronsin
bronsin's Avatar
I can understand why you might want to change plugs at 105k.
O2 sensor...I guess that's up to you. my experience is replacing parts which are working doesn't usually solve much...
Fuel filter....no....CT Scott has posted ff changes are not normally required also.
Good Luck!
Old 09-07-2015, 12:36 AM   #6
bairjo
[quote=07liftback;768215] Just seems like we ignore most maintenance items on this forum.
quote]
What?
Old 08-31-2015, 09:46 AM   #7
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
These are my spark plugs.. Acceleration was not smooth, changed them and the difference was huge! They did not lasted that much tho, I know my car has an oil leak so that could be the case
10 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 08-31-2015, 08:59 PM   #8
07liftback
07liftback's Avatar
How long did those plugs last you? What brand and model are those plugs? I ask because NGK plugs are oem for our cars.
Old 09-02-2015, 03:43 PM   #9
Kitt
Kitt's Avatar
those were Denso, they lasted about 12k miles
Old 09-02-2015, 05:49 PM   #10
Rigaud
Drives: 2009 Yaris
Irridium plugs for 1nzfe engines. OEM.
Old 09-03-2015, 04:35 PM   #11
07liftback
07liftback's Avatar
Didn't know, good info
Old 09-05-2015, 08:15 PM   #12
07liftback
07liftback's Avatar
The plugs I replaced were NGK bkr5egp which are G-power platinum plugs. So I'm guessing they weren't OEM since they weren't Iridium? The Iridium plugs sell for twice the price, anyone got any info on the difference between the two?
Old 09-03-2015, 04:55 PM   #13
brushforhire
Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR
We have seen aftermarket plugs cause alot of problems in Toyotas in general. We would get cars with miss issues all the time, and check the plugs and they were new a/m plugs. We would through OEM in and just like that, problems gone.
Our vehicles are very touchy about spark plugs.
brushforhire is offline   Reply With Quote
Old 09-03-2015, 06:23 PM   #14
Kitt
Kitt's Avatar
The ones I purchased at the dealer are Denso, same number/design that I would purchased somewere else. The only difference is that the ones I got from the dealer were inside a red box that says toyota genuine parts but the plug itself was branded denso. I tought they had more precise gap measure but no, aftermarket ones have the right gap as well.
Old 09-03-2015, 09:45 PM   #15
brushforhire
As long as it was the same denso number on the cermic they are definitely the same plug. Like you said, OEM denso's just come in a red box. The issue is when people buy anything the auto part stores say will work.
Old 09-03-2015, 10:13 PM   #16
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
If those were Denso's and they only lasted 12K something else is going on with your engine. I know you mentioned an oil leak, is it an actual leak or is it oil consumption? If you are burning a significant amount of oil it could affect the plugs. Still 12k seems like a really short lifespan.
Old 09-04-2015, 09:29 AM   #17
Kitt
Kitt's Avatar
correct, its actually oil consumption.
Old 09-06-2015, 06:11 PM   #18
tomm9050
Drives: Yaris 2008 HB
Best replacement plugs for an 08 HB?
tomm9050 is offline   Reply With Quote
Bigger Spark plug? samuraivince Performance Modifications 6 08-05-2014 04:09 PM
