Old 10-30-2017, 01:01 PM   #1
rabbito
rabbito's Avatar
Drives: 2012 Toyota Yaris Sedan (Vios)
what do you think about this???
2nd hand manifold...but i dont know why its rusted.....you think its alright? how can i test if its alright? hit it with the hammer few times to check? should i get heat wrap and wrap around it??
Sent from my SM-J730GM using Tapatalk
Brain: ATD E85 Timing Advance ECU
Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter
Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock
Electric: Volt Stablizer & Multi gauge obd2
Cosmetic: Toyota red emblem
rabbito is offline   Reply With Quote
Old 10-31-2017, 09:33 PM   #2
SirDigby
Drives: 2007 yaris 3 door
this is an intake?
evapo-rust!
https://www.youtube.com/watch?v=u03UtReREm0
Old 11-01-2017, 01:37 PM   #3
white89gt
Drives: 07 Yaris Hatch
Digby, that would be an exhaust manifold.
By looking at it, I would guess it was bare steel that someone left out in the weather. I would use it, but take a wire wheel to the mating surfaces first. Looks like it is just surface rust to me.
white89gt is offline   Reply With Quote
Old 11-01-2017, 02:02 PM   #4
tmontague
tmontague's Avatar
I thought at first a header and then I thought intake and settled on that
