Old 01-19-2018, 06:45 PM   #1
XXXXX
Drives: 2008 Yaris Hatch
Steering Rack Bolt Broken (AKA what size is it??)
YarisWorld,
My 2008 Yaris Hatch has had some noise lately. Going over bumps, cracks, etc. This city has notoriously bad roads and the car has 310,000 KM on it (about 193,000 miles).
Replacing the sway bar links fixed 95% of the noise but there was still a slight clunking and feedback in the steering wheel when going over bumps (especially when wheels turned)
Thought it was the sway bar bushings, so went under the car again and came across this:
Notice the nut is still attached. It broke off at the head of the bolt.
Does anyone know what size bolt that is? I'm hoping I can just get a metric grade 10.9 without going to the stealership for a $20 bolt.
XXXXX is offline   Reply With Quote
Old 01-19-2018, 07:49 PM   #2
ex-x-fire
Use an open end wrench to determine the size, if a 12mm open end fits snuggly over the threaded portion, that's your size. As for pitch, do you have any thread files?
If you go to a place like Fastenal they should be able to figure it all out.
Old 01-19-2018, 10:00 PM   #3
XXXXX
Thanks for the ideas. I don't have any thread files or gauges but I do have digital calipers.
I put my calipers on it and it came in at 11.75mm on the major diameter of the threads. Thread pitch per the calipers is 1.25mm. (EDIT)
So looks like a 12mm Fine bolt.
The nut is 17mm, but the bolt head is missing. Probably the same?
This was a flange bolt and nut. Is the size of the hex head size going to correspond to a certain shank and flange diameter? Rather than using a washer on either end I'd like to keep the same style.
Also, this isn't a nylock nut nor serrated. It has six stamped dots around the circumference of the flange. Distorted thread?
Finally there's the length. I guess any old length would do as long as it's long enough. I'd like the un-threaded portion to make it past the shear point of the bolted connection.
It occurred to me to use any old grade 8 bolt that would closely fit, but If someone had access to the OEM spec of course that's preferable.
It's gotta be in some kind of technical/service manual somewhere?
Old 01-19-2018, 10:07 PM   #4
XXXXX
Also... I wonder if that bolt flange was serrated?
Old 01-20-2018, 08:34 AM   #5
ex-x-fire
If your going to worry about all that then get the Toyota bolt, otherwise use washers & red Loctite.
Old 12-20-2018, 05:12 PM   #6
ojeysky
Drives: Sedan Yaris 2010
Originally Posted by XXXXX View Post
YarisWorld,
Attachment 59229
Am having this noise whenever I hit bumps or rough road, I have changed tie rods but seem not to be the issue. My mechanic is suggesting I change the entire steering rack, considering the cost of the I am wondering if the problem is the sway bar/bolt like yours. Can you perhaps show me with pictures where to look at under the car?
ojeysky is offline   Reply With Quote
steering Rack ends replacement how to Kitt DIY / Maintenance / Service 13 12-29-2018 02:34 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Steering wander, adjusting EPS assist Snubba Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 05-22-2012 05:39 PM
How much would you pay for a warranty supported steering wheel extension? (3d try) wornways General Yaris / Vitz Discussion 36 09-16-2009 10:16 AM
Upgrade Steering rack bushings?? aeipee13 Performance Modifications 1 07-14-2009 02:17 PM
