Old 01-30-2012, 05:38 PM   #1
Ratz
Ratz's Avatar
Drives: 2011 Yaris 4 Dr. Sedan
Controller Area Network
Can anyone please confirm that Yaris CAN interface (CAN Bus) complies to SAE J1939 data protocol. Could not find any information to confirm this.
Ratz
Cleverly disguised as a responsible adult.
Ratz is offline   Reply With Quote
Old 01-30-2012, 07:39 PM   #2
Low level wise is could be considered J1939 compliant, but it is officially J1987 compliant, uses the SAE J1962 terminal arrangement and high level packet wise is ISO 15765-4 compliant.
Old 01-30-2012, 09:07 PM   #3
Ratz
Ratz's Avatar
Thanks for your quick answer CTScott.
The reason I am asking is I like to install a temperature gauge in my Yaris.
Hooking up a scan tool to a DLC terminal and seeing engine temperature gave me an idea that I may use a temperature gauge compliant with CAN bus signal.
This way I can avoid inserting a temperature sensor in the radiator hose modification or fittings in the engine block and avoid running wiring from the engine compartment. Since I could just tap into DLC terminal wiring or instrument cluster wiring as signal wiring is available in both.
I guess I will send the manufacturer an email and see what they say about SAE J1987 protocol. Specifications state it is compatible with SAE J1939 data protocol.
Here is a link to the gauge I am considering as it has a nice large sweep. I could go with digital gauge but analog grabs ones eye attention faster.
http://www.vdo.com/generator/www/com...n_link_en.html
Any input is welcome.
Ratz
Old 01-30-2012, 09:23 PM   #4
I don't believe that gauge will work, as the SAE J1939 compliance is at the low level. The communication that allows a device to read PIDs, like the water temp fall under the high level ISO 15765-4 protocol.
Old 01-30-2012, 09:46 PM   #5
Ratz
Ratz's Avatar
Too bad, maybe one day everybody will get synchronized and use something like NMEA2000. I sent them an email already, to inquire if their gauge would work with SAE J1987 data protocol, now I am skeptical. Back to the drawing board.
Ratz
Old 01-30-2012, 10:25 PM   #6
auxmike
auxmike's Avatar
My Scanguage II tells me a whole bunch of stuff about the goings on inside the engine. Have you considered buying one?
Old 01-31-2012, 01:37 AM   #7
Ratz
Ratz's Avatar
Did not even know such a thing existed. Falling behind. Had a quick look and I am impressed. Soonest I find the best price with shipping to Canada I will get one. Thanks a lot for suggesting this little instrument.
Ratz
Old 01-31-2012, 10:08 PM   #8
Revsson
Why not PM CaliYaris (Garm), and see what kind of price he can get you.
He runs the Microimage site:
http://microimageonline.com/
http://shop.microimageonline.com/Electronics_c49.htm
http://shop.microimageonline.com/ScanGauge-II-SGII.htm
Maybe he can get a good shipping price to Canada.
I've purchased items from him, and he is great to deal with.
It's best to PM for details.
Old 01-31-2012, 10:31 PM   #9
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
If you've got an android phone you can get a bluetooth OBDII reader off ebay and download an app called "Torque" which shows all the readouts as well
Old 02-01-2012, 02:21 PM   #10
Ratz
Ratz's Avatar
Thank you all for the input. Ordered ScanGuage II from eBay, coming from Canada so no worries about duty. ($159.95 incl. shipping)
Cheers
Ratz
Old 02-01-2012, 04:19 PM   #11
Yury
Yury's Avatar
Drives: 2008 5 Door Liftback Auto
With ELM-327, an Android device and Torque you get a scan tool for about 30$. Torque can do many things including logging. One of the options is to log to their website, so can login and view your data in the map. Or import into Google Earth.
1999 Honda Prelude Base 5 speed (summer driver)
Yury is offline   Reply With Quote
Old 02-03-2012, 08:06 PM   #12
Ratz
Ratz's Avatar
You were right CTScott. Just received email from the manufacturer. The gauges I was considering will not work with SAE J1962 data.
I will be happier with ScanGauge II anyway.
Ratz
Rear Passenger Area Power Outlet DIY - Sedan fnkngrv DIY / Maintenance / Service 4 04-04-2019 07:03 AM
Group Buy for NTD 3Drive throttle controller twpanson Sponsors Classifieds Area 35 11-17-2009 10:18 PM
Blitz throttle controller 808_Yaris Performance Modifications 43 10-22-2009 04:36 AM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
