Old 10-14-2010, 03:25 AM   #1
guyver408
Drives: 2009 Yaris 5dr
What is it? Temp Sensor?
Folks, what is this item located on my 2009 Hatchback (behind the grill, right side in front of the radiator)? It's not firmly attached, looks like it is intended to flex. Is it a temp sensor? If so, what specs?
guyver408 is offline   Reply With Quote
Old 10-14-2010, 07:01 AM   #2
That's the ambient temperature sensor for the A/C. It is a attached to a plastic bracket that is supposed to be perpendicular to the radiator. It looks like the bracket for yours got knocked out of place.
Old 10-14-2010, 11:20 AM   #3
bankrobber
Drives: 2007 Yaris Hatchback
That's funny. I just noticed the same wire hanging down on mine. I hit a wood crate in the road 2 years ago and busted the front bumper and grill out. Never fixed it yet. Does that sensor turn on the fan for the A/C
Looking for a front bumper if anybody has a cheap used one
bankrobber is offline   Reply With Quote
Old 10-14-2010, 11:30 AM   #4
No, it's just used by the A/C's computer to make some decisions about compressor duty cycle.
Old 10-14-2010, 09:20 PM   #5
tonbon
Drives: 09 hatchback
my bracket looks excactly like his. it's a flexable bracket, like hard rubber. i guess to minimize shock?
i noticed it a month or so ago, and it took a bit of looking up to figure it out
tonbon is offline   Reply With Quote
Old 10-15-2010, 07:41 PM   #6
auxmike
auxmike's Avatar
Will the A/C work in the winter cold?
Does that sensor prevent the A/C from kicking on at a certain min. temp?
Old 10-15-2010, 10:21 PM   #7
The compressor will still run for defogging in the cold. I think it purely factors in for duty cycle. There is another temp sensor on the evaporator to prevent freeze-up.
Old 08-28-2018, 02:18 PM   #8
ojeysky
Drives: Sedan Yaris 2010
Though this is a old thread but I have an issue at the moment, my ambient temperature reads 81C but i noticed that I do not have the sensor in place and then my coolant temperature is high as well (between 95 and 105C). My question then is can the ambient temp contribute to my high coolant temperature?
ojeysky is offline   Reply With Quote
Old 08-29-2018, 03:27 AM   #9
ojeysky
Anyone with a response? @CTScot, kindly help with this question. Should I be getting ambient temperature data from my scanner when the sensor itself is not connected?
Old 08-29-2018, 08:08 AM   #10
dogsridewith
Drives: 2007 2-door hatchback
did you find the loose wire to the sensor? if not, maybe the connected sensor got tucked somewhere else?
Old 08-29-2018, 09:09 AM   #11
ojeysky
I actually found a wire around the location where the sensor is supposed to be and I could not find the sensor itself. Am adding a picture of the wire I found.
Old 08-30-2018, 04:01 PM   #12
B.B._07
Drives: 07 5dr
Without the ambient temp sensor connected any ambient temp reading you get on the scanner is worthless. The 81C reading you're seeing is probably a default value the car's ecu is using given that it's only seeing an open circuit on the ambient temp sensor circuit.
Old 08-31-2018, 08:18 AM   #13
ojeysky
I guess it's okay then since the weather is usually warm here and considering that the higher the ambient temp the better the AC performance in cooling the car interior.
Though I hope the ambient sensor is mainly for the AC
Old 11-18-2018, 08:00 AM   #14
ojeysky
I bought the ambient sensor but it doesn't seem to fit. Perhaps am looking at the wrong place?
Regards
Bad Air/ Fuel mixture sensor warning for ALL Yaris owners eric81 General Yaris / Vitz Discussion 31 04-21-2012 08:28 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 03:54 PM
Bad Speed Sensor? dmehak DIY / Maintenance / Service 33 01-05-2011 09:17 PM
Coolant Temp Sensor location? Yeti DIY / Maintenance / Service 7 05-06-2009 10:13 AM
outside temp on cluster??? ae92trueno7 Cosmetic Modifications (Exterior/Interior) 11 01-01-2009 10:36 PM
