08-18-2013, 08:48 AM | #1 |
Drives: YARIS 2 SOL BLACK Join Date: Aug 2013
Aux Input on TNS400
Hello all,
I have a Yaris 2 with TNS400 radio I discovered that it's possible to add aux input on this radio using a cable from Eclipse (AUX105) But of course, Ecplise doesn't sell anymore this cable On e-bay I managed to find a cable that looks like the Eclipse one http://www.ebay.com/itm/ECLIPSE-AUX-...item3cb6f396c4 I plugged the cable and.. it works..but only with left speakers! no sound at all on right speakers ( off course, I already tried balancing left to right ) So..I wonder if the wiring of my Axu105 cable is the correct one! Is there anyone with the TNS 400 and Aux105 cable working correctly? |
06-27-2014, 06:51 PM | #2 |
Drives: 2011 Scion tC Join Date: Jul 2012
Good question. I just got myself the same cable, same seller even, and I've got the same result. Even with the volume on the plugged in mp3 player turned all the way up, all I get is some faint scratchy quiet sound from the left speakers, and nothing from the right.
07-26-2014, 05:47 PM | #3 |
Drives: Yaris 1.4 D-4D Join Date: Nov 2008
I wonder if it has anything to do with the speakers selected for the navigation system indication. Can you try changing those settings, see if it has any effect.
I don't have the AUX cable, I have the iPod cable for my TNS400 and sound does come out on all speakers but, for example, when navigation directions are played, the music stops altogether. |
07-26-2014, 07:08 PM | #4 |
Mr. 155 and climbing
because made in Chinese sweat shop
07-26-2014, 07:20 PM | #5 | |
2ZR swap. DO IT! Ask how!
The pins on those are wrong. I've got a thread around here somewhere with the correct pinout...
Or maybe just a PM? Probably time I put this in a thread: Quote:
09-30-2014, 03:48 AM | #6 |
Drives: 2008 TOYOTA YARIS 1.4 D-4D Join Date: Sep 2014
Please forgive my basic electronics knowhow... I'm thinking of getting one of these cables but worried the speakers will be off balance. Are you saying it's possible to fix the pins to the right layout?
09-30-2014, 03:05 PM | #7 |
I'm not sure what you mean by 'off balance', but yes, you can change the connections. I made my own plug, so I had to find out the pinout anyway. If you buy the pre-made cable, you'll have to do the same thing as I did--i.e. test the pins to find the right wires, solder them to the jack, etc.
03-03-2016, 06:20 AM | #8 |
Hate to revive this threat, but man, thanks for the info!
I bought an AUX105 cable from eBay, and after plugging it in, I was shocked to see it didn't work properly! I was beggining to think the head unit had a problem, but after I saw your post I ended up fixing the cable and everything seems to be OK!!! I even bought a used AUX-in socket (previously used in a 2009 Yaris that had AUX-in from the factory) and rewired a connection so that the AUX-in is under the safety break :D I'm a sucker for everything being well-organized! Thanks for the info you posted, CrankyOldMan. |
03-03-2016, 06:28 AM | #9 | |
08-02-2018, 02:57 AM | #10 | |
Drives: Yaris Navi 2008 Join Date: Aug 2018
What can be useful to say is that the pinout of the DIN 13 connector is not the same as you are showing. The pin number 5 in the front of the connector corresponds to the pin number 8 in the rear view of the plug (there are some numbers written on it). Taking into account the numbers on the back face of the DIN connector, the wiring is: GND: 7 Left: 6 Right: 5 This info may be helpful if someone wants to purchase a rewired cable from an external supplier. Thank you very much for your help! |
10-05-2018, 07:01 AM | #11 |
Drives: Yaris MK1/2 D4d, Auris MK1 D4d Join Date: Mar 2018
Thanks for this information, very useful but there is so much conflicting information on the internet at the moment, i found at least 4 different configurations for the same job and I am not sure which one will do the job.
Can anybody throw some light please? If anybody can help and knows the correct pin configuration can you state whether the pinout is when looking at the radio unit plug, the cable pins or the cable plug back face. |
10-05-2018, 09:16 AM | #12 |
The good news is that you really can't hurt anything by connecting them the wrong way around (they're just inputs). Try one pair at a time and see if the sound comes from the correct speaker.
Here's the pinout of the cable (pins) side, looking at the pins. The connector (sockets) is the mirror (1 is 4, 2 is 3, etc.). |
10-07-2018, 03:11 AM | #13 | |
Am i correct assuming that your post further up is the right way to go? ./-----13-----\. /-9-10-11-12-\ \-5--6--7--8--/ .\1--2--3--4-/. .........^........... Pin 6 is ground for both cables. Pin 7 is left and Pin 8 is right. Is this looking at the cable pins from the front? |
10-08-2018, 08:50 AM | #14 |
Those are the correct pins. Look at the attached image in the post above for the pin numbering.
10-09-2018, 04:00 AM | #15 | |
The pins front (cable side) The pins end where soldering goes (cable side) Car plug/socket (Radio unit side) ? |
Similar Threads | ||||
Aux Input Wire | nobleboy | In Car Entertainment + Electronics (audio / video / alarm) | 25 | 06-03-2015 05:25 AM |
DIY: Aux Input Jack Adapter | TinyGiant | DIY / Maintenance / Service | 11 | 11-10-2012 05:33 AM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
Aux Input Trouble | boeduur | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 04-07-2011 11:44 AM |
High pitched whine using stock head unit / aux input? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 8 | 02-02-2007 12:49 PM |
