Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > UK
Old 01-26-2019, 01:45 PM   #1
Mountain man
Drives: Toyota Yaris
Water leak drivers footwell Yaris 07
Toyota Yaris 07 two door , water in drivers footwell after rain. It is not engine coolant. Windscreen has been re sealed. Toyota are struggling to find the cause. Any ideas please?
Mountain man is offline   Reply With Quote
Old 01-26-2019, 02:29 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
If it's wet after rain and the car has been sitting, then you have leak somewhere.
If you are driving and it gets wet, it might be a lost drain plug.
Old 01-26-2019, 03:12 PM   #3
Mountain man
yes, its wet after rain. The water is clean, all floor bungs are in place and sealed.
Old 01-26-2019, 03:28 PM   #4
IllusionX
Then sit in the car, ask someone to hose down your car and look around inside where water might be coming in.
My guess would be by the wiper cowl
Old 01-26-2019, 04:44 PM   #5
Mountain man
Thanks for your replies. Going to have to think outside of the box for this one. Its been in a Toyota main dealer workshop twice now. They have carried out the usual water pouring tests and found nothing. next step is to remove the entire dash board, which I am hoping to avoid as that will cost a lot. Hoping somone has experienced the same problem nd found the answer.
Old 01-27-2019, 04:42 PM   #6
Mountain man
Anyone else had this problem?
Old 01-27-2019, 09:36 PM   #7
dogsridewith
Drives: 2007 2-door hatchback
You've confirmed the HVAC box drain tube (USA passenger side) is not clogged?
Old 01-30-2019, 08:07 AM   #8
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
That's what I came to suggest!
firebird1999us is offline   Reply With Quote
Water leak in driver footwell aliahmed13 DIY / Maintenance / Service 6 12-08-2018 05:27 PM
Water leak to passenger side AND driver side TMR3 DIY / Maintenance / Service 7 05-21-2017 07:19 AM
Water on the floor of my yaris vincentg DIY / Maintenance / Service 3 06-07-2014 07:04 AM
