Old 05-02-2018, 02:34 PM   #1
mrfuzzy
Drives: 2000 Yaris GS 1.0
1999 Yaris / Echo - rear drum bleeder screw access?
Repaired the brake lines on the wife's yaris, however having issues getting a hose and a wrench on the drum bleeder screws as they are fitted at an angle and struggling to get an air tight seal whilst being able to turn the wrench
Any tips?
mrfuzzy is offline   Reply With Quote
Old 05-02-2018, 02:50 PM   #2
bronsin
bronsin's Avatar
I used to bleed the brakes without a hose on the bleeder bolt. Messy but doable. Perhaps you could cover the bolt with a rag which would absorb most of the brake fluid.
Somehow I dont think this advice will be taken.
More unpalatable examples of advice I have given: you can own a low flush toilet without the trouble and expense of installing a new one. Just flush only when brown.
Tags
bleeding, drums, help needed, rear, yaris 1999
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 06:04 PM
