Old 11-01-2013, 09:42 AM   #109
dobrik
Drives: Yaris 2013 1.33 CVT
Hi All,
Fitted the Scott's CC kit on Yaris 2013, 1.33 1nr-fe CVT.
Touch 'n Go head unit didn't ask for security code after the battery disconnect, also all settings were not reset (radio, BT, sound settings).
To get out the airbag from the wheel with side gear switches - is real pain, took me like 40 min.
CC works like a charm :), the plastic cover panel didn't fit though, waiting for Scott to figure that out.
Update: Scott emailed me the partnumber of the cover panel and I got it from the local dealer for $10 with taxes (btw Scott had refunded me the wrong part cost at the moment I've reported it)
dobrik is offline   Reply With Quote
Old 12-04-2013, 04:54 PM   #110
er6nphil
Drives: Yaris 2013
Does anyone know if this will work on my 2013 1.4 d4d ?
Thanks
er6nphil is offline   Reply With Quote
Old 12-04-2013, 05:06 PM   #111
Thanks
No. Unfortunately only the 1.33L European Yaris supports cruise control.
Old 12-04-2013, 05:11 PM   #112
er6nphil
Drives: Yaris 2013
Is there any kit that you know about that does ?
Old 12-04-2013, 08:31 PM   #113
I have seen a couple of aftermarket kits listed on European websites (I posted a link in one of the threads on here). Those kits sell for $400 to $600 US from what I have seen.
Old 12-12-2013, 06:05 AM   #114
maxcrack
Drives: Yaris 1.0 Active 2012
And the 1.0L European Yaris with MMT... It is supported?
maxcrack is offline   Reply With Quote
Old 12-12-2013, 06:34 AM   #115
I do not believe that the 1.0L supports cruise. Only the 1.33L wiring diagrams indicate that cruise control is available on it.
Old 12-15-2013, 11:47 AM   #116
SecondYaris
Drives: 2013 Yaris HB
Just a quick post to thank Scott, just installed the cruise control on my 2013 3 door. This is my second Yaris first was a 2007 that got totaled in 2012 with 245000 miles on it. The install was quick and easy like 20 minutes. The hardest part was being careful releasing the 3 pins that hold the (horn airbag assembly), don't force it just press it with light force you will see the assembly unlock and you will hear it. Works great and the cover was worth the extra $5, makes it look nice and clean, just like OEM at 1/8 the cost.
Mods so far with 2003 miles on it performed in this order, TRD sway bar, Tanabe Medallion axle back, and of course cruise control. Next lightweight belt pulley, then AFE intake.
SecondYaris is offline   Reply With Quote
Old 01-20-2014, 01:16 PM   #117
modify34
Drives: Yaris Multidrive S
hi, I have a 2013 model toyota yaris multidrive s car. Is it possible for me to attach it a cruise control
modify34 is offline   Reply With Quote
Old 02-08-2014, 10:47 AM   #118
Drbailey
Drives: Yaris 2012 3 door SR
Hi.. First post.... I have a 3 door 2012 European SR model Yaris with the four steering wheel buttons.... Looking to fit cruise control... Scott do you supply kits for this car? I was told when we bought the car CC was not an option....
Thanks
Dave B
Drbailey is offline   Reply With Quote
Old 02-08-2014, 12:40 PM   #119
Thanks
Dave B
Welcome. Which engine does your SR have? To be best of my knowledge cruise only works with the 1.33 L.
Shipping to the UK is no problem.
Old 03-07-2014, 04:01 PM   #120
Stenis
Drives: Hybride
Hello new here / anybody know if it possible to install Cruise Control to a Yaris 2012 hybrid XP13M(A) from Europé.
Stenis is offline   Reply With Quote
Old 04-01-2014, 03:26 PM   #121
scmoky
Drives: Yaris 2012
Ask CTScott, but I think that is possible, because in our country the hibrid can have CC in stock new car. You have 1.5l engine?
scmoky is offline   Reply With Quote
Old 04-01-2014, 05:35 PM   #122
Yes. As mentioned above, cruise is an option of the Yaris Hybrid, so they should all be setup for it.
Old 04-04-2014, 03:53 PM   #123
Stenis
Drives: Hybride
Yes i have 1.5l Engine. I have asked an toyota dealer and they said it cost about 1250 usd to fit CC in my car.
Old 04-04-2014, 08:35 PM   #124
Remove the lower steering column cover and snap a picture of the black connector that plugs into the spiral cable assembly (the black plastic ring behind the steering wheel that allows the connections within the steering wheel to rotate). My bet is that the wires are present for cruise control, so all you will need to do is to add the stalk under the airbag.
Old 04-05-2014, 03:48 PM   #125
Stenis
Drives: Hybride
Ok i will do so. My understanding is to remove the cover for CC take a picture. Do i need to remove airbag? for the picture? I will try to do so and take a picture soon and hope for a good reply
Old 04-05-2014, 04:19 PM   #126
No. Just remove the two screws that are exposed by turning the steering wheel to either side and the one down by the tilt lever
cruise control. 2012
