Old 09-28-2016, 10:57 AM   #1
mik23
Drives: yaris 2005
YARIS Clutch Pedal Noise
Hi can someone help
it is coming from inside the car looks a springy noice
what i found
SYMPTOM
The clutch pedal makes a creaking noise when it is pressed.
PROBABLE CAUSE
The coils of the clutch pedal assist spring are rubbing against each other, or the clutch release fork pivot bolt is dry.
CORRECTIVE ACTION
Determine the cause of the noise, then replace the clutch pedal assist spring, or lubricate the clutch release fork pivot bolt.
Can someone advise where is clutch release fork pivot bolt.
and how can I lubricate this.
mik23 is offline   Reply With Quote
Old 10-01-2016, 01:15 PM   #2
mik23
Drives: yaris 2005
Sorted
Just under the clutch pedal where it links with the main cylinder I spray in the hole with white grease.
All quite now
thanks
HELP PLEEEASE!!! my yaris starts whenever I step on the clutch pedal. trini_per4mance DIY / Maintenance / Service 42 03-27-2017 03:59 AM
Squeaky Clutch Pedal? Kaotic Lazagna DIY / Maintenance / Service 43 05-29-2016 01:15 PM
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 84 09-30-2012 12:25 PM
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW VitzBoy General Yaris / Vitz Discussion 5 09-05-2010 08:53 PM
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
