Old 10-27-2013, 01:49 PM   #1
Hard_Yaris
Drives: 07 Yaris
CV axle DIY?
recently after putting on my winter tires i noticed both drivers and passenger sides have torn cv boots. I think they are both clicking but for sure the passenger one is.
I searched the forums and found some useful information, but now need some questions answered.
Is not repairing this going to lead to expensive transmission repairs?
How long can i safely ride with torn cv boots?
While I'm told to replace the entire cv axles with new ones, what other components should i replace while doing the cv axle replacement?
Also curious about changing the transmission fluid, will the fluid come spilling out when i remove the cv axle?
Just want to have all my parts together before taking on what seams to be a monstrous job. Would like to go into the mechanic with some knowledge, or if its a Novice job that i can handle DIY'ing it.
My car has 180K and im looking at rebuilding the entire front end so that i can drive this car for another 180k front struts are about 90k old..
Any help would be awesome!!
Thanks,
Hard_Yaris is offline   Reply With Quote
Old 10-27-2013, 06:21 PM   #2
If they are clicking they will not last long before failing catastrophically. That will mean the joint completely failing, but damage to the tranny itself is unlikely.
When you pull the axle on either MT or AT, fluid will spill out, so you do want to drain it first (and ideally not put the used fluid back in).
Old 10-28-2013, 12:14 PM   #3
Hard_Yaris
Drives: 07 Yaris
Thanks CTScott..!
What about other parts that I should replace while getting to the axle?
Ball joints, stabilizer links, struts, wheel bearings?
Cheers
Old 10-28-2013, 01:14 PM   #4
Originally Posted by Hard_Yaris View Post
Thanks CTScott..!
Cheers
With 180K km, I would check all of those before disassembling the car to determine if they are due or not. I personally would not replace all of those just for the sake of doing so, but if any are even close to due, then this is definitely an easy time to do so.
Old 10-28-2013, 02:08 PM   #5
CB Spoolmak
CTScott:
Can the CV axles be removed independently from each other? According to some internet sources some cars need one side removed & then a "drift" to displace the other side.
How difficult is it to get the CV axle to slide out from the transaxle housing?
CB Spoolmak is offline   Reply With Quote
Old 10-28-2013, 02:20 PM   #6
Originally Posted by CB Spoolmak View Post
CTScott:
They come out independently on the Yaris. I find them extremely easy to remove, as there is a nice notch on the inner joint that l get a giant flat blade screwdriver onto and then whack the handle of the screwdriver with a hard rubber mallet.
Old 10-28-2013, 09:43 PM   #7
Hard_Yaris
Drives: 07 Yaris
i do want to replace the minimal parts required, but looking at the amout of parts that are invoived in removal of the cv axles, i wnated t
Old 10-28-2013, 09:44 PM   #8
Hard_Yaris
Drives: 07 Yaris
... i wanted to make sure nothing was overlooked.
Old 10-28-2013, 09:48 PM   #9
Hard_Yaris
Drives: 07 Yaris
i am not 99% sure how to verify busted front end parts,... but if these parts were showing signs of grease loss rubber or metal wear, i could identify... what would i be looking for?
Old 10-29-2013, 03:32 PM   #10
Hard_Yaris
Drives: 07 Yaris
Got a mechanic to look over the front end... he says both stabilizers and shafts need to be replaced... hes going to charge me $150 for labour... getting a parts quote for after market shafts and Toyota brand stabilizers.
Old 01-01-2016, 04:29 PM   #11
Murtaza_murti
Drives: Toyota Belta
Would the CVT fluid leak while replacing axles?
Murtaza_murti is offline   Reply With Quote
DIY Cruise Control FAQ (2006-2010 Yaris) CTScott DIY / Maintenance / Service 467 10-18-2022 10:20 AM
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
DIY Change Your Interior Light Grey Panels to Black KCALB SIRAY DIY / Maintenance / Service 64 01-22-2015 01:25 PM
DIY: LED side mirror installation eTiMaGo DIY / Maintenance / Service 85 06-24-2011 11:48 AM
revamping the DIY section supmet Suggestions - Feedback - Questions 7 03-23-2009 02:01 AM
