03-19-2019, 09:10 AM | #1 |
Drives: 2008 Sedan Join Date: Sep 2017
Used Yaris Only Came With One Key...
Hello. I'm new to posting here, and I'm sorry if my search-fu is weak. I'm trying to learn things more or less on my own and I'm a little stuck.
I got a used 2008 Yaris sedan last year, and the dealer said they only had one key. It's not even a Toyota key. It says Axxess+ 35R and has no fob or anything. I'm assuming it's a valet key as well since it doesn't open my trunk (I know, I did a bad job scoping things out before buying). I've tried to do some research, and so far I'm gathering that I don't have an immobilizer because my ignition has no black ring and is all metal? My first question is, will I be able to have a key with the fob buttons at all? Second, am I pretty screwed when it comes to getting a new key? Is this one of those things where I will need a new ECM and am I forced to go to a Toyota dealer to handle this? I'm just trying to educate myself on my options here and I don't have any knowledgeable folks around me right now, so any pointing in the right direction is appreciated. I am happy to learn. Thank you, all! |
03-22-2019, 04:28 PM | #2 |
Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
dealer
The dealer may be able to cut you a key by the VIN. Give them a call and find out.
04-19-2020, 01:16 AM | #3 |
Drives: 2007 yaris sedan base Join Date: Apr 2020
I agree with Allenwagen's post. The Access key is a universal blank like you get from Home Depot. If you wish to have a Toyota branded key, ny dealer will gladly cut you as many as you want. Your vehicle does not have a transponder key, so a solid brass key will work just as well as the fancy dealer key for a fraction of the price.
05-02-2020, 12:47 PM | #4 |
Drives: 2015 yaris L Join Date: Jun 2016
Odd that the key for the ignition doesn't fit the doors? Dealer may be able to cone up with a door key? If not try a lock smith, if you get a door key you can remove the ignition switch and may be able to file the tumblers so the door key fits the ignition too.
05-03-2020, 12:07 AM | #5 |
A locksmith can re key the locks for you. The door and trunk lock are a breeze to remove and install.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Yaris 2012 Sedan Key with remote | faisalloe | General Yaris / Vitz Discussion | 5 | 09-27-2012 10:29 PM |
Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
2010 Yaris Sedan - Need Key Programmed to the Immobilizer | vst | General Yaris / Vitz Discussion | 0 | 04-17-2011 04:29 PM |
