Old 08-20-2019, 06:49 PM   #19
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Originally Posted by myfirstyota View Post
I'm also on b8's with tein stechs. I cut the factory bumpstop. All seems well so far
Thanks for the feedback.
On Instagram
On Wheelwell
#TeamWheelwell #ForTheBuild
Old 12-16-2019, 07:17 PM   #20
ElMagnifico
Drives: 2012 Sedan
Originally Posted by ern-diz View Post
Gotcha, thanks for the input.
To clarify, I'm not the OP and that wasn't my picture. I'm just in a similar position where I'm running Tein S. Tech springs and am about to replace the OEM shocks/struts with the B8's. I'm happy to buy the FEBI stops, new OEM stops and use at full size or new OEM stops and cut. Just trying to find the ideal setup.
Since my B8 struts will be new in-box, I'm going to wait to see if a stop is included. If so, what size and go from there.
Any updates?
ElMagnifico is offline   Reply With Quote
Old 12-21-2019, 11:38 AM   #21
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
Mine were new in-box, all they came with were the nuts for the top of the shocks. No bumpstop included
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 12-23-2019, 02:29 PM   #22
ern-diz
ern-diz's Avatar
Originally Posted by ElMagnifico View Post
Any updates?
Thanks for checking in. Between work and life, I haven't looked at Jegs or one of the other usual suspects for better than OEM bump stops and top mounts, so I haven't installed the B8's yet.
Worst case, I know I can go with a fresh set of OEM stops and mounts and just cut the stops like I did when I installed the springs.
On Instagram
On Wheelwell
Old 12-24-2019, 10:59 PM   #23
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
FWIW...When I installed the MI springs (the way back like 8 years ago) i DIDNT cut my bumpstops and my reason was well better to have a little too much then not enough. Then I went to Tokico blues and still didnt cut them. About a year and 130~ thousand miles later I switched back to the stock springs and my oem bumps were still in fine shape and my shocks are just fine
And I thoroughly use my car ;)
-Greg...the Exhaust Freak.
-'10 PW sedan 107whp/110wtq, full exhaust, suspension goodies
-'82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe swap in progress
-96 Tercel coupe, LSD, suspension bits
-96 Tercel 4dr...future caged track slut
Old 12-30-2019, 01:35 PM   #24
ern-diz
ern-diz's Avatar
Worst case, you're just losing a bit of travel over big bumps and making the stops work a little harder, right?
On Instagram
On Wheelwell
Old 01-08-2020, 01:12 AM   #25
hachi-roku_fan
Drives: 1986 Toyota Corolla
Does anyone know how the TRD set up is configured?
hachi-roku_fan is offline   Reply With Quote
Old 01-08-2020, 12:11 PM   #26
Is your question does a car equipped with TRD suspension utilize different bump stops than one with standard suspension? If so, the answer is they both use the same bump stops.
Old 01-08-2020, 12:12 PM   #27
hachi-roku_fan
You answered my question! I figured the TRD set up would not require me to mod the oem bump stops
Old 01-09-2020, 01:24 AM   #28
ElMagnifico
Drives: 2012 Sedan
i dont know if this helps anyone but on my Tein Street Advance Z's they require the fronts to be cut to 60mm and the rear to remain unaltered. cutting the fronts down leaves the stiffer upper portion. i'm going to change them to a softer 58mm option i found.
PK's HDR Tutorial PK198105 Photo-Video-Media Gallery 47 06-13-2012 02:51 AM
Bump stop length for drop springs. PetersRedYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 02-17-2010 09:37 AM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 05:02 PM
Option and Best motoring DVDs for sale kustom play Items for Sale by private party 1 07-08-2009 08:04 PM
I found My New Sound/DVD/Nav system! pp.sweet In Car Entertainment + Electronics (audio / video / alarm) 17 07-05-2009 01:47 PM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
