Old 10-03-2018, 01:49 PM   #1
Pinchlite
Drives: 2007 yaris HB
Quick orange flash under rpm needle?
I took a flashlight and looked into cluster but dont see an icon where light is comming on.
Maybe I am seeing things?Its just a quick orange flash know and then.LIke I said its just underneath the rpm needle in line with the other icons.
Pinchlite is offline   Reply With Quote
Old 10-03-2018, 10:40 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
A picture and circle where you see it might help..
Sent from my VTR-L09 using Tapatalk
Old 10-03-2018, 10:56 PM   #3
jayeh
Drives: '08 Yaris LB
Low washer fluid?
Misfire making the check engine light flash?
jayeh is offline   Reply With Quote
Old 10-04-2018, 04:42 AM   #4
Pinchlite
It is in this area.Thing is I see no icon/outline when I shine light.
https://i.imgur.com/3AzSAwL.jpg
Old 10-04-2018, 07:45 AM   #5
bairjo
you should be able to see the symbol when you start your car before it goes out. I would then refer to your owners manual to see what it is. Could be washer fluid or the alternator/battery. You could also just top off your fluid and see if the light stops flickering if you don't have the owners manual.
bairjo is offline   Reply With Quote
Old 10-04-2018, 08:00 PM   #6
Grindstone
Drives: Yaris 2007 Hatch
99% you're on low washer fluid. When you hit a bump or something, it briefly goes under the sensor level.
Grindstone is offline   Reply With Quote
Old 10-04-2018, 08:08 PM   #7
IllusionX
Washer fluid light is on the right though.
Old 10-04-2018, 08:13 PM   #8
tmontague
tmontague's Avatar
I'm going out on a limb here and saying you're seeing things... ;)
Old 10-06-2018, 08:34 PM   #9
bairjo
So did the op ever figure this out
Toyota Yaris Optimal RPM for Highways Anquietas General Yaris / Vitz Discussion 12 04-28-2017 05:59 AM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 04:40 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Mid-Atlantic 0 09-24-2012 03:10 PM
Yokohama Orange, You Glad? Yar Is Word Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 08-24-2010 09:29 AM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 12:41 AM
