Old 02-06-2014, 07:39 AM   #1
Benskizy
Drives: Toyota Yaris
Can I relocate the aux port?
I have an Manual 07 Yaris sedan and I was wondering if it was possible to relocate the auxiliary port from that passenger side pocket to the one of the two empty slots that are between the shifter and emergency brake?
Benskizy is offline   Reply With Quote
Old 02-06-2014, 08:08 AM   #2
Yes. That is where it is located on liftbacks. You would have to lengthen the cable (4 wires) to have it reach.
Old 02-06-2014, 05:25 PM   #3
willisjm193
Yoshi 2.0
willisjm193's Avatar
Drives: 2007 Manual Sedan
I did this to mine, but a little differently than CTScott suggested:
  1. I removed the connector from the aux bezel, leaving the connector itself behind the passenger side pocket, and put the bezel into the open spot next to the ebrake.
  2. Then I used a 3.5 aux cord with one female end and one male end. Plugged it in, routed it under the center console.
  3. Secured it to the bezel in place of the previous plug with hot glue.
  4. The cover that was in the panel next to the ebrake fit nicely where the aux port had been.
Pros: Quick and simple; no need to splice any wires. It functions like I need it to with convenience.
Cons: If I ever need to move it back, the hot glue might be difficult to get fully out. Also, the radio won't automatically change to AUX mode when you plug something in, because it thinks something is always plugged in.
willisjm193 is offline   Reply With Quote
Old 02-06-2014, 05:41 PM   #4
There you go - That keeps it simple.
Tags
aux adapter, auxiliary, auxiliary port, ipod adapter, relocate
Aux Port - Canadian 2006 Yaris spryguy007 In Car Entertainment + Electronics (audio / video / alarm) 42 04-17-2022 12:33 PM
aux port 400 dollar yaris In Car Entertainment + Electronics (audio / video / alarm) 11 11-14-2013 09:37 AM
Anyone had an OE head unit apart? (aux port) CoryM In Car Entertainment + Electronics (audio / video / alarm) 2 05-23-2012 09:42 PM
How do I can install (AUX) Port ??....>> boadel In Car Entertainment + Electronics (audio / video / alarm) 8 02-15-2010 05:40 AM
Switched amp for AUX port with Aftermarket stereo? CtrlAltDefeat In Car Entertainment + Electronics (audio / video / alarm) 6 05-28-2009 02:34 AM
