11-19-2012, 05:55 AM | #1 |
Drives: 2007 Toyota Yaris Hatchback Join Date: Sep 2012
Horn Malfunction
About two weeks ago, my car started beeping when I got into it - I wasn't placing my hands near the steering wheel at all. I noticed the center of my steering wheel is slightly slanted on the left side moreso than the other - it's very noticeable when you glide your finger tips across it. Anyways, to stop the beeping, I removed the horn fuse. I thought it was a computer malfunction (I assumed) and tried putting the fuse back in, but the horn started blowing by itself again. Can anyone help me out? Thanks ^^".
11-19-2012, 06:27 AM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
If you hit the steering wheel hard at some point, you may have bent the sheet metal frame, which acts as the horn switch. In the picture below, with the airbag removed, the frame around the airbag is the piece I am talking about. The other possibility is that if you recently installed cruise control, you may have not properly aligned one of the bolts when reinstalling the airbag.
11-19-2012, 07:25 AM | #3 | |
11-19-2012, 07:34 AM | #4 |
If the metal frame is bent, you should be able to bend it back into shape. There are also some plastic pieces that act as insulators, and one of them may be broken. If that is the case, they would not be considered replaceable by Toyota, but they actually just bolt in. I have a complete horn switch assembly if you end up needing parts.
11-19-2012, 08:15 AM | #5 | |
12-14-2012, 02:40 AM | #6 | |
Drives: Yaris Join Date: Dec 2012
Thank you in advance!!! |
12-14-2012, 02:46 AM | #7 |
The bolt you see is the one that secures it to the steering wheel cover. It also has a washer on the bottom.
12-14-2012, 02:51 AM | #8 |
I borrowed this pic from a member post to show the overhead view of where they are located @ 12, 4, and 8 o'clock position and what they are supposed to look like not broken
12-14-2012, 11:51 AM | #9 |
That's definitely broken. Toyota only sells the entire airbag assembly. I have a couple of sets that I have harvested for the angry drivers out there.
12-14-2012, 05:11 PM | #10 |
Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
Good to know these can break...... i will be more gentle next time someone cuts me off
If it has boobs or wheels sooner or later your gonna have problems with it |
11-05-2022, 05:03 PM | #11 |
Drives: Yaris 2008 Join Date: Nov 2022
Thread Tools | |
Display Modes | |
Similar Threads | ||||
My horn install... | Goose | DIY / Maintenance / Service | 7 | 01-29-2016 04:10 PM |
Transfer truck horn and compressor | coheed | Items for Sale by private party | 5 | 12-28-2011 08:26 PM |
where is my horn located? 2007 3 door | Suey 1958 | General Yaris / Vitz Discussion | 6 | 11-27-2011 09:57 AM |
NEED ENGINE CHECK LIGHT CODE LIST | Attitude | Forced Induction Forum | 12 | 04-11-2011 06:38 PM |
Toyota Premium Horn | Meteorite_Marty | Cosmetic Modifications (Exterior/Interior) | 22 | 02-18-2009 11:28 PM |
