Old 11-21-2017, 08:58 AM   #1
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
Window horizontal rubber piece replacement
2010 Yaris sedan hatchback. Driverside window rubber piece that runs horizontally on window sil ; hence , if your window was all the way down and your arm was resting on the door, your arm would be contacting this rubber piece I'm trying to describe. What's the difficulty in replacing this piece, mine has torn?. TIA
frog13 is offline   Reply With Quote
Old 11-21-2017, 04:49 PM   #2
http://www.yarisworld.com/forums/showthread.php?t=58024
Old 11-21-2017, 07:47 PM   #3
frog13
Tw200--excellent!
Wee Yaris , THANK YOU. Strange name for this part however , no wonder I could find anything about it. Generally it just snaps apart and new one snaps in......correct. TIA
Old 11-21-2017, 11:13 PM   #4
frog13
Tw200--excellent!
Wee Yari. In time I'll have to replace a marker light or two. Any links on the front grill / bumper pins . I would like to have additional pins incase I break some of them while taking apart the grill area when replacing bulbs TIA
Old 11-21-2017, 11:14 PM   #5
frog13
Tw200--excellent!
Sorry for the small print , not sure why that happened
Old 11-22-2017, 08:28 AM   #6
Are you referring to the little football shaped lights on the fender above the wheel? If so, you don't need to take anything apart to remove them.
Old 11-22-2017, 12:25 PM   #7
frog13
Tw200--excellent!
No. The marker lights within the headlight assembly.
So the front of the car has to be disassembled. Thats why ill need the anchors / pins for reassembly , I'm sure I'll break a few.
Old 11-25-2017, 10:06 PM   #8
frog13
Tw200--excellent!
Do folks order the push pins / anchors for the body work , hence front bumper area, from Toyota or where? TIA
Yaris Verso: Reset power window jam protection togo DIY / Maintenance / Service 3 01-10-2013 10:03 AM
Electronic Window Closer mod cali yaris In Car Entertainment + Electronics (audio / video / alarm) 8 11-11-2011 11:16 AM
Help: Rear Door Small Window Install nick.dollimount DIY / Maintenance / Service 7 09-22-2010 02:22 PM
Driver window replacement EtienneGignac General Yaris / Vitz Discussion 0 06-20-2010 02:26 PM
Front window replacement cost jambo101 DIY / Maintenance / Service 7 06-11-2009 11:07 PM
