Old 09-30-2017, 08:29 PM   #1
fourbangingfun
fourbangingfun's Avatar
SRS Light On (B1805/52 Code) Even after having recalls done
Hey guys,
07 sedan with 199k miles here. I recently had the SRS airbag light pop on, and stay on. I also happened to the get the *URGENT* recall notice for the passenger airbag recall, so I brought my car into the dealership for the first time in my 4 years and 100k miles of owning it.
They did a few recalls for me - the driver's side window switch, the driver's seat rail, and the spiral cable replacement.
However, my SRS light is still on. I had them scan it and print me out a code, which was B1805. I followed up and used CTScott's method of jumping the two electrodes in the OBDII port, and only got a code 52 there.
So I believe I have a B1805/52 code. What the heck do I do now? I'm afraid to monkey with the connections under the passenger seat because I don't want to the airbag to deploy on me. I might bite the bullet and just pay the dealership to fix this one... ugh
Thanks guys/girls!!
fourbangingfun is offline   Reply With Quote
Old 10-07-2017, 08:37 PM   #2
fourbangingfun
Bump? Anyone have an airbag light on AFTER getting the clockspring/spiral cable recall done??
Old 10-07-2017, 11:35 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Just wondering if they plugged the airbag back in right or did it come disconnected , that will cause a code .
Sent from my ONEPLUS A5000 using Tapatalk
Old 10-07-2017, 11:48 PM   #4
IllusionX
Drives: 07 Yaris Sedan Aero
Looking up your code. Here is what I found.
• Center airbag sensor assembly detects line short
circuit signal in front passenger side squib circuit 5
times during primary check.
• Front passenger side squib malfunction
• Center airbag sensor assembly malfunction
And trouble area are:
• Instrument panel wire
• Instrument panel wire assembly
• Front passenger airbag assembly (Front passenger
side squib)
Hope this helps you find what's wrong.
Sent from my SM-G930W8 using Tapatalk
Testosterone: The New Synthetic Oil bronsin Off-topic / Other Cars / Everything else Discussions 23 12-15-2013 06:02 PM
full tank japle Fuel Economy Forum 15 12-10-2013 11:05 AM
srs / airbag light after head unit install? KwonSau In Car Entertainment + Electronics (audio / video / alarm) 7 12-24-2008 02:04 AM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 06:56 PM
