Old 03-08-2017, 03:25 PM   #19
JimKellyfan
JimKellyfan's Avatar
Drives: 2010 Yaris Sedan
I only use 3 for towing or insanely steep down grades
Old 09-07-2019, 09:47 PM   #20
carstudiopk
Drives: Toyota Belta 1.3, 2008, 3SZFE
Originally Posted by yougojay View Post
...and drive, Drive, DRIVE! - It will work automatically. If you go up a steeper hill, it will most likely drop down a gear or two. I live in the Appalachians in Western North Carolina, when I come down the mountain it drops down & slows the car automatically. Have driven a lot of vehicles that I had to lay on the brakes to slow down, not this one. This is a sweet little transmission...just put it in drive and GO
That's called Engine Braking
Sent from my vivo 1727 using Tapatalk
carstudiopk is offline   Reply With Quote
