01-09-2020, 12:24 AM | #1 |
Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
Intermittent airbag light problem.
DTC: B1625 I have this problem of airbag light coming on about once a week when I start the vehicle, then when I go to shut I off and start back up it goes away, I tried cleaning electrical connectors, I tried swapping the driver side airbag sensor with the passenger and still code will come back for passenger side. I am slowly losing my mind, someone please help me! Do I need to check for shorted wiring?
01-09-2020, 08:48 PM | #2 | |
Drives: 2015Yaris, Son's car, 10 Prius Join Date: May 2010
recalls
Did you do your recalls? They are absolutely free. See below. NHTSA Vehicle Safety Recalls Recall Number 14V168000 Recall Date 04/09/2014 Component AIR BAGS:FRONTAL:DRIVER SIDE INFLATOR MODULE Summary Toyota is recalling certain model year 2006-2008 RAV4, 2006-2010 Yaris, 2008-2010 Highlander, and 2009-2010 Tacoma, Corolla, Corolla Matrix and General Motors Pontiac Vibe vehicles. In the affected vehicles, the steering column assembly contains electrical connections to the driver's airbag module housed in a spiral cable assembly, which includes a Flexible Flat Cable (FFC). Due to the shape and location of the FFC's retainer, the FFC could become damaged when the steering wheel is turned. Consequence If the FFC is damaged, connectivity to the driver's air bag module could be lost and the air bag deactivated. The failure of the driver's air bag to deploy in the event of a crash that typically necessitates deployment increases the risk of injury to the driver. What Owners Should Do Toyota will notify the Toyota vehicle owners, and General Motors will notify the Pontiac Vibe owners. Toyota sent owners an interim notification letter in May 2014 to advise owners of the recall. Toyota will mail owners a second letter when remedy parts are available. General Motors sent Pontiac Vibe owners an Interim letter on June 20, 2014 notifying them that parts are currently unavailable. General Motors sent notices to the Pontiac Vibe owners on September 15, 2014, that a remedy is available. The recall began on October 27, 2014. Owners may contact Toyota at 1-800-331-4331. Owners may contact General Motors at 1-800-762-2737. |
01-10-2020, 01:59 AM | #3 | |
01-13-2020, 01:15 AM | #4 |
Drives: Yaris 06 - 5dr hatchback Join Date: Aug 2015
If you plugged another sensor in and it still threw a circuit code it indicates the problem isn't with the sensor but with the wiring or internal to the airbag module. I can't say I've ever messed with an airbag system before. I would guess it's only safe to check the wires for continuity with the battery disconnected because of the risk of you sending a signal which triggers the airbag. I would wonder if the wires have rubbed through somewhere between the sensor and the cable grommet through the bulkhead. It might not be necessary to replace the harness. If you can find where the break is you could repair it with one of those solder shrink connectors.
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles UK to Nordkapp in a Yaris
01-13-2020, 06:55 AM | #5 |
Drives: 2007 Yaris Sedan Join Date: Apr 2009
The 2007 service manuals. Indicate the SRS system has a back up power source.
When you work on it. Allow at least 90 seconds after the ignition is turned off and the battery negative is disconnected. Before doing any work on the system or it is possible the air bag may deploy accidentally. |
01-14-2020, 04:15 AM | #6 |
I would leave 10 minutes once the power has been disconnected on any airbag system.
01-15-2020, 08:08 AM | #7 |
Drives: Yaris 2008 Sedan Join Date: Nov 2010
I've been noticing my airbag light randomly turn on while driving. If I turn the car off, and back on, it goes away too. Mine doesn't seem to generate a code though, I ran a scan with Bluetooth ODBII and torque, and didn't show anything. Wonder if it's the LED wiring grabbing power somehow. I saw it come on after a semi hard brake on a downhill slope.
01-16-2020, 11:42 AM | #8 | |
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped Join Date: Feb 2016
I was under the impression you needed expensive equipment to fetch those codes...although I could be wrong
No one suspects the Yaris. Xd/2zr-fe Swap/Build Thread http://www.yarisworld.com/forums/showthread.php?t=61427 Bolt-in 3.75" Suspension Lift Build Thread http://www.yarisworld.com/forums/showthread.php?t=61577 |
01-16-2020, 12:45 PM | #9 | |
PS. I took the car in and asked about recalls when I first got it. They told me all recalls had been done, unless they were lying (wouldn't put it past them,) it must be something else. |
01-17-2020, 04:08 PM | #10 | |
05-13-2021, 10:26 AM | #11 |
Jennifer1
Drives: Rav4 Join Date: May 2021
The airbag warning light should only stay on when there's a problem with the airbag system in the car. Every time you turn on the car, the computer in the vehicle checks the system. The light comes on for a few seconds and then goes off to show that it's working. You'll need to reset the airbag light in this case. I think this is common knowledge though, it shouldn't be a problem. I have a rav4 and I feel like Toyota is a really amazing car brand. I only had a problem with it through the years and it was super easy to resolve, just got a toyota rav4 transmission ecu repair and I've never had any more problems with it since then, so I don't think I'll switch to another brand any time soon.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Help me 3rd gen 2015 model b1806 code srs airbag light | Hassannazir314 | Third Gen Yaris General Discussion | 7 | 09-22-2017 04:55 PM |
2008 Yaris No airbag light at all | rudycoop | DIY / Maintenance / Service | 6 | 09-15-2017 10:22 PM |
2009 Yaris airbag light staying on | #30 | DIY / Maintenance / Service | 7 | 08-27-2015 05:57 AM |
Passenger airbag light on making turn signals and cabin fan not blowing? | thatbryanguy | General Yaris / Vitz Discussion | 16 | 04-02-2012 08:42 PM |
Airbag light is on | Taiyaki | DIY / Maintenance / Service | 4 | 05-26-2009 08:47 PM |
