Old 01-18-2017, 09:40 PM   #55
IllusionX
Drives: 07 Yaris Sedan Aero
They are aimed exactly the same height. It's the way the headlights are made for LHD, passenger side always angles up toward road side signs.
Old 01-18-2017, 09:48 PM   #56
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Yup it does
Sent from my SM-G935F using Tapatalk
Old 01-18-2017, 11:45 PM   #57
Originally Posted by Exiwolfman View Post
Passenger side can stay higher it's the driver side that should be lower so one does not blind on coming traffic or both even works well too.
The picture makes the passenger hotspot look like it sits higher than the driverside.
I am well aware of LHD and RHD cutoffs. The LHD cut off looks like
____/ ____/
What I was saying is in the picture, the "horizontal line" looks like it's higher than the drivers side, like:
..........._____/
_____/
but like I said, it could just be the way the car was parked in relation to the house.
Old 01-18-2017, 11:49 PM   #58
That's what it should look like.
Old 01-18-2017, 11:52 PM   #59
But I just realized the door is actually not on the same plane as the garage, so that's why the passenger side appears to be higher than the driver side.
Old 01-19-2017, 08:50 PM   #60
IllusionX
I started backing off and turning on a slanted driveway.
Old 01-20-2017, 02:40 PM   #61
Yaris709
Drives: 07 yaris
How do I adjust the lights on my yaris sedan guys? The lights aren't aimed properly would like to get them aimed correctly
Yaris709 is offline   Reply With Quote
Old 01-20-2017, 02:48 PM   #62
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Adjust screw at top open hood
Old 01-20-2017, 11:02 PM   #63
On the back of each headlight, iirc, there are metal adjustment knobs (it's hard to miss). I believe it's an 8mm to adjust.
Old 01-29-2017, 12:55 AM   #64
BennyLava
Drives: 1987 Silverado
Originally Posted by tmontague View Post
Fwiw i only had condesation on one or m'y headlights after m'y original install when i tried reusing thé oem sealant. I then went To Lowes and bought à proper sealant that stays flexible and since then have had no issues in all types of weather and temperatures.
Imo if you don't want to deal with properly sealing them or the potential headache then don't do the mod, or pay for someone else to do it. Or like you did, manually point them down so they don't blind others - however this ends up leading to poor light patterns like you stated which brings me back to my previous point of do it properly or not at all
Do you have a thread where you took apart the Yaris headlight and installed the lenses? I don't want to blind anyone, but I want those LED's! I'm no stranger to DIY so hopefully I can just copy whatever you did. I have a 2009 sedan. I hope you don't lose any brightness and/or visibility by using a lens. But I have to have some kind of cuttoff for the beam where I am, because as far as I know its against the law to have lights that blind people and you will get pulled over for it.
Old 02-11-2017, 12:06 AM   #65
tarkus
tarkus's Avatar
Drives: 2006 Yaris RS 3-Door
An informative article about halogens and HIDs - http://www.ebay.com/gds/Xenon-and-HI...1832221/g.html
tarkus is offline   Reply With Quote
Old 03-06-2017, 01:54 AM   #66
ryryAP2
Drives: 05' Honda S2k, 15' Toyo Yaris
And if you don't want to take apart the headlights to do a projector retrofit (but can some how remove that shield/cover thing through the bulb opening), you can use these: https://www.amazon.com/Rover-Project...ini-projectors
I would have went with them, but they're built in HID bulbs, and are 6000k (wouldn't want anything more than 5000k unless they're Osram CBI). I wouldn't use anything less than Morimoto bulbs for HIDs, but that's just me.
Newbie here! Was wondering if anyone has tried these rover projector bulbs? Wanted to do a PnP without retrofitting projectors.
ryryAP2 is offline   Reply With Quote
Old 03-06-2017, 07:20 AM   #67
Yaris874
Yaris874's Avatar
Drives: 07 yaris hatchback
I got one different brand on ebay for 22 am goin to try to do it today may be
Sent from my SM-G935T using Tapatalk
Yaris874 is offline   Reply With Quote
Old 03-06-2017, 11:29 AM   #68
ryryAP2
Awesome! Let me know how they work out. I'm thinking of pulling the trigger on the Amazon Car Rover ones. If anything they have a good return policy at Amazon
Old 03-06-2017, 11:32 AM   #69
Yaris874
Yaris874's Avatar
The ones on ebay ar not built in hid
So the Amazon are is the only difference
Old 03-06-2017, 11:34 AM   #70
Yaris874
Yaris874's Avatar
But u still have to buy the ballast on the Amazon ones the ebay ones u buy ur Owen so u can pick ur color and 35w or 55w
Old 03-06-2017, 12:05 PM   #71
ryryAP2
From what I understand they only come with 6000k. Amazon sells a kit with the bulbs, ballasts ,and harness relay. The ballasts are 55w, but I was thinking of getting 35w. hmmmmmmm.
Here's the link: http://a.co/gysL9HO
Old 03-06-2017, 12:14 PM   #72
tarkus
tarkus's Avatar
Can you share the eBay link?
Sent from my phone with Tapatalk. Please excuse any typpos.
Having a few very very odd issues after LED conversion Astroman In Car Entertainment + Electronics (audio / video / alarm) 8 08-03-2014 05:53 AM
Does anyone realize yarisworld is getting 'less busy'? caineroad General Yaris / Vitz Discussion 84 11-05-2013 12:19 AM
FREE Projector Headlights OR LED Tails in exchange for appearance in how-to video V70R_Blackbrick California 4 10-13-2013 10:57 PM
Yari gets a sway bar and a rim change (again) D&D Photo-Video-Media Gallery 8 09-16-2013 01:10 AM
Cruise Control kicking itself out GTBaker Third Gen Yaris General Discussion 9 09-05-2013 09:39 PM
