02-04-2014, 10:46 PM | #109 |
Drives: 2009 Meteorite Metallic LB MT Join Date: Oct 2008
bairjo - nice job on the video!
I shouldn't admit this, but I installed my foglights when I replaced the horn with one of those premium horn kits. I never ran the wires. Been too busy or lazy to finish the job. I'd really like to have a stalk like that, but too chicken to mess with airbag stuff, though you make it look easy. That would probably take me all day to do, and would have to borrow some tools. However, maybe when it's warmer, I'll get motivated. BTW, I got the Micro Image kit...yikes, that was a few years ago now that I think of it. Where does the time go? Thanks again for the video and to CTScott for all his expertise on the Yaris! |
02-24-2014, 03:17 AM | #110 |
Drives: yaris hatchback 2013 Join Date: Feb 2014
ok now mi problem is that I have the same kit, but I have a yaris 2013 and I don't want to cut any cable because the warranty, what can I do, don't know anything where to plug the wires o the 15 fuse go please help
02-25-2014, 12:34 AM | #111 |
Regarding cutting cables and warranty. Go ahead and cut...I asked the dealer about this when I had my 08...they said it will not void anything unless what you do damages something. For example, if you took your car to a pro to have a remote start installed....snip snip. No issues with the warranty. Just be sure you do your homework and follow the advise of the folks on here that tell you how to do it right. You will be fine...
04-13-2014, 10:27 PM | #112 |
Drives: Toyota Yaris Sedan Join Date: May 2012
I own a Yaris, (Thailand / General Area) year 2011 model and i've installed an aftermarket fog lamp. Does anyone here knows how to get the fog lamp indicator turned on the dashboard without replacing the OEM stalk. I'm too chicken out to remove the airbag and the oem stalk as it involves removal of the steering clock spring. Does anyone here knows which wire harness or pin to tap into for supplying the 12vdc power to light up the dash fog lamp indicator? Any help would be greatly appreciated. Thanks.
04-15-2014, 04:06 PM | #113 | |
Drives: Sedan 07 Join Date: Oct 2012
it should be pins 3 and 4 for the stalk connector under the steering column cover, but if you choose the route of tapping into the cluster (as ours here who don't have the stalk switch also don't have wires 3 and 4 under the stalk connector) you should be able to supply 12V on Pin 7 of the 16-pin connector (the shorter one and the one near the driver). You can read more here: http://yarisworld.com/forums/showthr...=indicator+fog If nothing works, you might want to check if there's an LED behind the fog indicator on the cluster by gently lifting that black plastic part (where the speedometer/tach is printed on) |
04-18-2014, 05:42 AM | #114 | |
04-28-2014, 03:35 PM | #115 |
Drives: Yaris Sedan Join Date: Mar 2012
Instrument panel light of yaris Belta Sedan (Vios) not funtion.
Some one know how to repair it. |
04-29-2014, 03:20 PM | #116 | ||
09-11-2014, 02:00 AM | #117 | |
You can use aftermarket switch without cutting the wire harness apart by just tapping the 12vdc power source from the aftermarket switch to fire up the indicator at the dashboard. Just connect it to the hole of the relay show in green using a spade connector. Hope this works for all of you out there. |
09-11-2014, 02:08 AM | #118 | |
Hope this helps all of you out there. Cheers! |
01-13-2015, 05:25 PM | #119 |
can i use this switch on my 2015 yaris
03-21-2015, 06:56 PM | #120 | |
Drives: 2009 Yaris Sedan Join Date: Mar 2015
So the red and white wire is coming from the aftermarket switch is this correct?
04-20-2015, 04:45 PM | #121 | |
Drives: 2007 Toyota Yaris Hatchback Join Date: May 2006
I did get my lights working by going through the firewall, which was a pain, and connecting by this method, without connecting to the outside fuse. Something happened and then they did not work anymore and I really didn't have time to try to fix it until now. I'm looking to start fresh and was wondering if anyone could recommend a good kit that is pretty easy to install. I don't plan on installing the stock. I also have a denso relay from my first attempt. |
04-21-2015, 11:07 AM | #122 |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
Honestly, one of the best kits would be the micro-image one. It's a shame the're they've closed shop. I was lucky enough to get my hands on one for my '09.
That kit had you plugging the fog lights into a connector in the engine bay fuse box, rather than running a separate wire through the firewall. Not only that, but it would also illuminate the indicator light in the instrument cluster.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
04-22-2015, 05:37 PM | #123 |
Do you remember the name of the kit so I could try and find it online.
04-22-2015, 06:06 PM | #124 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
The Micro Image kit was a custom kit of their own.
08-22-2015, 07:07 PM | #125 | |
Newbie
Drives: vios 1.3E Join Date: Aug 2015
TIA |
08-23-2015, 09:12 PM | #126 |
Newbie
oops double post
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Fog light install | 07yaris_fe | Cosmetic Modifications (Exterior/Interior) | 10 | 07-20-2010 01:18 PM |
Looking for the Toyota Fog Light install | RocknRollRon | DIY / Maintenance / Service | 33 | 06-13-2010 06:46 PM |
DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
Before I start calling around: fog light install prices | St_G | Cosmetic Modifications (Exterior/Interior) | 4 | 03-17-2007 09:45 AM |
Finally installed oem ebay fog light for hatchback | Adriaan | General Yaris / Vitz Discussion | 6 | 12-27-2006 04:24 PM |
