Old 05-27-2018, 08:17 AM   #1
Yaris709
Drives: 07 yaris
Ticking under acceleration?
My yaris has been ticking the last few months. Happens when accelerating. Is this do to needing a valve adjustment? I dont think it's the manifolds as it doesn't go away after the car warms up and I can't see any exhaust fumes leaking from the manifold.
Yaris709 is offline   Reply With Quote
Old 05-27-2018, 03:06 PM   #2
miiser
miiser's Avatar
Drives: yaris 2009
Timing chain ?
miiser is offline   Reply With Quote
Old 05-27-2018, 04:48 PM   #3
johnny_vitz
Drives: 2005 Toyota Echo
It is very common for the gasket between the manifold and the downpipe to start leaking. It usually makes the most noise on acceleration when it goes
05' Echo Hatch - Greddy Supercharger - rear disc
johnny_vitz is offline   Reply With Quote
Old 05-27-2018, 07:25 PM   #4
Yaris709
Drives: 07 yaris
Wouldn't that make the car louder? Or am I incorrect. I always thought that ticking with exhaust leaks usually went away after the motor warmer up?
Old 05-29-2018, 11:36 PM   #5
johnny_vitz
Depending on the size of the leak, yes. It will get louder as a leak gets bigger.
Sometimes leaks in the manifold itself will go away/be less noticeable when hot...but most other leaks (rotted pipe, gasket leaks, etc) will stay the same when warmed up
Old 05-30-2018, 01:28 AM   #6
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Is it definitively different than rattlling? Things to double check is possible loose heat shield that when you accelerate cuz the exhaust does move a little. Maybe the Cat or Resonator. Does the ticks get more in frequency as you accelerate more and more? or just the same. How about neutral cruising.
Check out my Build thread:
Old 06-01-2018, 05:00 AM   #7
Yaris709
Drives: 07 yaris
Just cruising along it's fine no ticking but soon as I accelerate the ticking starts. It's a consistent tick as well, doesn't get louder/quieter. I'm puzzled as where to start to look and dont want to spend repair bills on things that aren't in need of repair
Old 06-01-2018, 11:58 AM   #8
DarkShadowFox
Worlds Prettiest Yaris.
DarkShadowFox's Avatar
Drives: 2015 Yaris LE 3door 1F7
if its a tapping noise its your valves. you can hear the engine ticking naturally with sensitive ears because the engine is so tiny and theres not alot of NVH dampening.
Checkout My Build Thread: https://yarisworld.com/forums/showthread.php?t=58963
Im autistic about 3rd gen yarises. ask me anything.
DarkShadowFox is offline   Reply With Quote
Old 06-03-2018, 06:20 PM   #9
Yaris709
Drives: 07 yaris
Its definitely not a normal sound as it only started a couple months ago, its very noticeable.
Old 06-03-2018, 07:54 PM   #10
DarkShadowFox
make a recording of a noise or something. these things need to be like diagnosed by ears.
Toyota Recalls auxmike General Yaris / Vitz Discussion 554 04-10-2018 03:10 PM
Debating acceleration techniques Amdkt7 Fuel Economy Forum 19 04-02-2013 02:22 PM
Yaris acceleration problem myahya UK 3 04-01-2012 05:38 PM
Did Toyota Prius Driver Fake Unintended Acceleration? JBougie Off-topic / Other Cars / Everything else Discussions 33 03-15-2010 11:24 AM
more acceleration with smaller tire diameter? Stiv Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 02-28-2009 08:50 AM
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
