Old 05-31-2018, 09:22 PM   #1
RMcG
Drives: 2008 Yaris Hatchback
Determining proper tension for new serpentine belt
I recently installed a new serpentine belt. I used a Bando belt from Rock Auto that is supposed to be as good as an OEM belt. Everything went fine, but the belt started squeeling more and more shortly after installation, so I tightened the belt using a crowbar for leverage.
Since tightening the squeeling has stopped, but I am worried that the belt is too tight. People on the forum here have cautioned that if the belt is too tight, it could adversely affect bearings in the parts contacting the belt.
Is there a good way to objectively determine proper belt tension?
Thanks,
R.
RMcG is offline   Reply With Quote
Old 05-31-2018, 09:36 PM   #2
CB900F2
Drives: 08 Sedan
See the attached TSB with tension spec....
Old 06-01-2018, 07:16 PM   #3
RMcG
Thanks CB,
I appreciate getting the specs. The belt tension specs appear to require a belt tension tool, the Denso BTG-20 Belt Tension Gauge, correct?
I do not, of course, have such a gauge. I have found a couple of interesting videos the give a trick of twisting the belt 90 degrees to determine appropriate tension. Do you or anybody else have any comments?
https://www.youtube.com/watch?v=FMiB3CnZpRc
https://www.youtube.com/watch?v=-f1eE9U-khU
Thanks,
R.
Old 06-01-2018, 08:04 PM   #4
castles
Drives: 2008 Yaris
you could see if this guys squeaky belt solution works for you...
https://www.youtube.com/watch?v=HRrVMtyIqIY
castles is offline   Reply With Quote
Old 06-01-2018, 08:21 PM   #5
RMcG
Thanks, in fact I already saw this video and the solution of slowly turning the key worked for a while, but the squeeling got worse.
R.
Old 06-01-2018, 10:19 PM   #6
B.B._07
Drives: 07 5dr
That video is useless, guy just offers up a theory when the real solution is obvious (the belt needs to be tighten).
I wouldn't be overly concerned with the belt being to tight. I've changed the serpentine belt on a Toyota 1.8L 1ZZ engine which is the big sister 1.5L 1NZ in the Yaris. The 1ZZ has an auto tensioner and it puts a lot of tension of the belt. If you're super concerned about the tension being too high you can loosen the tension to the point that it starts to squeak and mark that point on the tension adjuster with a paint pen/whiteout/nail polish/scratch awl/etc. Then tighten it a little bit, mark the point, and test it and repeat until the squeaking goes away. I used that method and my belt is nice and quiet.
Old 06-01-2018, 11:07 PM   #7
scylla
Drives: 2015 Yaris L
Yep, best way to do it right there B.B.
A Yaris belt is so easy to tighten that it only takes a few tries to get it right if you have an ornery belt.
scylla is offline   Reply With Quote
Old 06-02-2018, 08:35 PM   #8
Billiam
Drives: '10 White Yaris 4D LB
We bought a 2010 4 door hatch with 126k on the clock back in January. The belt was squeaking quite a bit. So I replaced it with a new Dayco. It was no better. No matter how much I cleaned all the pullies and the belt, no matter how much I adjusted the tension, it still squealed some.
So I went with a Gates belt. Dead silent. Zero noise. The only adjustment I've made was when I put it on.
If you want to enjoy your car, stay off of the internet.
Old 06-06-2018, 12:31 AM   #9
RMcG
Originally Posted by RMcG View Post
Thanks CB,
Thanks,
R.
Thanks to everybody for their comments. I checked the belt tension using the 90 degree twist method advocated in the youtube videos above and the belt tension was fine. So I have just left the tension as is and I have no noise at all. Problem seems solved, at least for now.
Thanks,
R.
Tags
belt, determining, proper, tension
Which serpentine belt? courtartanis DIY / Maintenance / Service 0 11-30-2017 11:32 AM
Yaris serpentine belt!!! Ramon1691 DIY / Maintenance / Service 9 04-11-2016 11:00 AM
Serpentine Belt Replacement - Is it possible to get it too tight? keith204 DIY / Maintenance / Service 5 05-25-2015 04:52 AM
Squeal from Engine after replacing Water Pump and Serpentine Belt vidfan DIY / Maintenance / Service 7 06-24-2014 10:41 AM
Lost Serpentine Belt NickNickNick DIY / Maintenance / Service 33 07-31-2011 12:28 PM
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
