Old 04-09-2009, 10:24 AM   #1
la_scanner
Drives: 2007 toyota yaris
freeze frame - i swapped coils just to humor myself.
Okay, so if you guys remember me posting on here about mechanic telling me to bring car in saying that he needs to switch coil 1 with coil 4 and coil 4 with coil 1. well i did it last night. just for fun. heres what i came up with. the check engine light was on immediately. i then put back to normal (or how it was b4 i touched it) then i reset light. and so now i will wait again and see when light comes on again. this is fun.
Report#: 7
Report Date: 4-9-2009 (12:18 AM)
Vehicle Year: 2007
Vehicle Make: Toyota
Vehicle Model: YARIS
Stored:
P0354 Ignition Coil D Primary/Secondary Circuit
Pending:
P0304 Cylinder 4 Misfire Detected
MIL ON
MisFire Monitor Complete
Fuel System Monitor Complete
Comprehensive Component Monitor Complete
Catalyst Monitor Not Complete
Heated Catalyst Monitor Not Supported
Evaporative System Monitor Not Complete
Secondary Air System Monitor Not Supported
A/C System Refrigerant Monitor Not Supported
Oxygen Sensor Monitor Not Complete
Oxygen Sensor Heater Monitor Complete
EGR System Monitor Not Supported
DTC for which Freeze Frame was Stored P0354
Fuel System 1 Status Open Loop
Fuel System 2 Status Not Supported
Calculated LOAD Value 41.18 %
Engine Coolant Temp 123.80 °F
Short Term Fuel Trim - Bank 1 0.00 %
Long Term Fuel Trim - Bank 1 -4.69 %
Engine RPM 1363 rpm
Vehicle Speed Sensor 0.00 mph
Ignition Timing Advance #1 Cylinder 8.50 °
Intake Air Temperature 71.60 °F
Air Flow Rate Mass Air Flow Sensor 0.56 lb/min
Absolute Throttle Position 19.22 %
Time Since Engine Start 0 sec
Bank 1 - Sensor 1 Equivalence Ratio 1.00
Bank 1 - Sensor 1 O2S Voltage 3.30 V
Commanded Evaporative Purge 0.00 %
# Warm-ups since DTC Cleared 0
Distance since DTC Cleared 1.86 mi
Barometric Pressure 28.64 inHg
Bank 1 - Sensor 1 O2S Current 0.00 mA
Catalyst Temperature Bank 1 - Sensor 1 914.90 °F
Catalyst Temperature Bank 1 - Sensor 2 661.46 °F
Control Module Voltage 13.89 V
Absolute Load Value 20.78 %
Commanded Equivalence Ratio 0.87
Relative Throttle Position 0.00 %
Absolute Throttle Position B 51.76 %
Accelerator Pedal Position D 16.08 %
Accelerator Pedal Position E 31.76 %
Commanded Throttle Actuator 18.82 %
Time since DTC Cleared 0 hr 19 min
la_scanner is offline   Reply With Quote
