Old 02-19-2019, 12:16 PM   #1
pribek
pribek's Avatar
Drives: Man
Send a message via ICQ to pribek Send a message via AIM to pribek Send a message via Yahoo to pribek
Fujitsu Ten connector description
Does anyone know the description of the connector for the OEM radio Fujitsu Ten 86140 (Toyota yaris 2016, hybrid).
Something like power, loudspeakers, USB ...
Thanks
pribek is offline   Reply With Quote
Old 02-20-2019, 01:43 PM   #2
bob225
Drives: Yaris
Power and speakers are an easy one, connects2 and Autoleads do SOT leads that give you the male and female plugs these are standard across Toyota
What are you trying to do ?
The power and speakers use a standard 090 connectors 10 and 6 pin (iirc they should be sumitomo)
bob225 is offline   Reply With Quote
Old 02-20-2019, 02:54 PM   #3
pribek
pribek's Avatar
Drives: Man
On OEM radio I do not have Navigation, and the subsequent purchase of Nav module is too expensive, about 400 USD.
For this money, I hope that I can buy a good Android radio that will have most of the features (not all) as well as OEM radio.
I am trying to find a way to connect some of the Android radios to existing connectors while retaining as many features as the existing OEM device (steering wheel controll, USB, rear camera, etc).
Old 03-05-2019, 06:55 AM   #4
bob225
Drives: Yaris
Sorry for the late reply
To fit a aftermarket stereo you will need a facia, iso adapter and steering controls adapter
Usb/aux in is a simple job remove the factory one and fit http://www.connects2.co.uk/Product/P.../CTTOYOTAUSB.2
The rear camera may be a issue
Avoid cheap Chinese headunits they can be poor quality, the steering wheel controls rarely work correctly
Old 03-05-2019, 01:40 PM   #5
pribek
pribek's Avatar
Drives: Man
Thank you for your answers.
After talking to people from Connect2 and your answers, I definitely gave up on installing Android devices.
As an alternative solution I bought a "Video Cable for Toyota Touch 2" ($ 45) and "Smartphone / iPhone Wi-Fi Mirror Car Adapter with RCA and HDMI Outputs" ($ 65).
Connected Android smartphone to wi-fi Mirror and launched Navi (iGO) from smartphone.
PROS:
All of the smartphone applications on your Toyota device are displayed. Video / audio etc
CON:
Occasionally sound problems.
I manage the application exclusively from the smartphone.
Something more complicated to start.
Sorry about my bad english
Old 03-06-2019, 06:34 PM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
There are pretty good ones out there. joying is one. Has all the features, and support steering wheel controls.
Sent from my CLT-L04 using Tapatalk
Old 03-06-2019, 11:39 PM   #7
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
AFAIK, all the Yaris Fujitsu Ten radios use the same connector.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 03-07-2019, 02:39 PM   #8
pribek
pribek's Avatar
Drives: Man
Is this question or statement?
View an image from post no. 1.
Old 03-07-2019, 02:41 PM   #9
IllusionX
It's a statement.
Why don't you just get a Metra wiring harness? Saves you from cutting the stock connectors.
Old 03-08-2019, 02:33 PM   #10
pribek
pribek's Avatar
Drives: Man
How Much I Know The Metra has no adapter for the 28th pin connector.
Old 03-08-2019, 02:51 PM   #11
IllusionX
I'm not sure what is connected on your car, but there are standard connectors for most Toyota.
If you tell us what you are trying to fit, we'd be able to find solutions for you.
What's plugged into the 28 pin?
Old 03-08-2019, 03:06 PM   #12
pribek
pribek's Avatar
Drives: Man
The pin assignment for the 28 pin connector is according to the image attached.
Old 03-08-2019, 03:12 PM   #13
IllusionX
Your image is blurry.
For the steering wheel controls, you need the Metra ASWC-1 interface and the AX-TOY28SWC harness. But the 28pin look like only for the 3.5mm aux in.
Old 03-09-2019, 02:31 AM   #14
stidnam
Drives: Starlet
Re the 28 pin connector - alternatively you can buy the male plug and terminals for a couple of dollars from somewhere like rs online and then crimp the 3 wires on a 3.5mm lead to match sw1 sw2 and swg
stidnam is offline   Reply With Quote
Old 06-02-2019, 02:20 PM   #15
pribek
pribek's Avatar
Drives: Man
Finally, an Android radio was installed.
My choice is:
Pumpkin AS0272B, Android 7.1, 2gb, 32gb, quad core, 7 inch (167 eur). In addition I bought:
Mini Car REVERSE REVERSE BACK UP CAMERA (9 eur), ISO Car Radio Wire Harness Adapter Plug Cable For TOYOTA (3 eur)
Car Radio Stereo CD Player Antenna Adapter Adapter Audio Cable Female for Toyota (2 eur).
A total of about 180 euros.
It took about 4 hours to install. Most time is spent on tapping the cable to the rear camera and connecting the cable to the SWC.
FM reception is OK, GPS OK ....
There is no CAN adapter required for SWC connections.
All the possibilities from OEM HU are also present on the new HU (SWC, gps, reverse camera.
It also has all the features of Android devices (GPS, Torque-OBD, wi-fi, screen mirroring, photo and movie view, DAB ...)
Attached is a few pictures:
Old 06-25-2020, 04:30 PM   #16
radden
Drives: Toyota Yaris XP13
Hello,
That installation looks awesome!
I know that this post is very old, but it turns out that I ran into the same issue. I want to replace the original radio by an android one. The biggest problem that I'm facing is that I can't find a proper fascia. Where did you get that plastic adapter? There are lots of them but they include the whole circle. I would like to install the same as you with the open circle at the left side.
Also, did you need to rewire / solder any cables? What adapters did you buy?
Thank you in advance.
radden is offline   Reply With Quote
Old 06-26-2020, 03:34 PM   #17
pribek
pribek's Avatar
Drives: Man
The Fascia adapter was a problem for me too. It’s expensive and it didn’t seem to be what I wanted.
Therefore, after installing the HUD, I fastened the original frame, measured these two pieces marked in the picture, cut them out of plexiglass, coated (glued) with artificial leather. On the outer original frame these two pieces are glued with a hot glue gun.
It has been looking good for a year now and no problem.
As it says in the post above, I additionally bought:
1. ISO Car Radio Wiring Harness Adapter Plug Cable For TOYOTA Lexus Hot. Link: https://www.ebay.com/itm/ISO-Car-Rad...rksid=p2057872. m2749.l2649
2. Car Radio Stereo CD Player Antenna Adapter Adapter Audio Cable Female for Toyota. Link: https://www.ebay.com/itm/Car-Radio-S...%3AIT&_trksid= p2057872.m2749.l2649
3.Mini CAR REVERSING REVERSE BACK UP CAMERA 4 LED WATERPROOF FOR XTRON CAM009. The link is not active.
All that was needed to connect the SWC was to cut the wires and solder them (or install detachable connectors).
If you need more details, say or write PM
Sorry for the bad English.
Greetings from Croatia
test drive of 2014 Scion iQ Ten Series 428CobraJet General Yaris / Vitz Discussion 2 12-31-2015 12:51 AM
Top ten list: 12 yaris Third Gen Yaris General Discussion 24 08-11-2012 09:47 PM
Ten Cheapest Cars To Own... MadMax General Yaris / Vitz Discussion 18 08-27-2009 12:14 PM
Top Ten Most Fuel-Efficient and Reliable Used Cars bdc87 General Yaris / Vitz Discussion 9 03-10-2009 01:26 PM
