Old 02-11-2019, 07:41 AM   #1
sceh
Drives: yaris 2004
VVTI oil change
2004 Yaris VVTI with the MMT box. When I change the oil in the engine does this also change the oil in the box or is there another filter and another sump?
Dumb question I know but my Haynes manual conveniently says the MMT system is not for amateurs so it has no details of any kind..
Thanks for any advice
sceh is offline   Reply With Quote
Old 02-11-2019, 11:19 AM   #2
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
At the box, transfer your pallet. This is a separate unit.
I like very much travel
MickZEL is offline   Reply With Quote
Old 02-11-2019, 12:21 PM   #3
sceh
Drives: yaris 2004
I don't really understand your reply - sorry. Can you expand?
Old 02-11-2019, 01:09 PM   #4
MickZEL
MickZEL's Avatar
Drives: Yaris sedan
There must be a filter in the gearbox; there is also a drain plug in the gearbox pan. You need to know all the information on the car, then you can find the part number
http://toyota.epcdata.ru/
Old 03-07-2019, 07:08 AM   #5
Mask Rider Blac
Drives: 2013 Yaris Sedan MT
Pardon me, are you asking that if you change the oil in the engine, does it also change the oil in the transmission?
Please note that engine oil and gear oil are two different oils and have two different locations. The oil pan for the engine oil has 14-millimeter bolt, hence, the gasket is also 14mm; while, the transmission has a fill bolt and a drain bolt (in case of manual transmission) that measure 19mm for both bolts and the gasket also measures 19mm.
Sent from my SM-G7102 using Tapatalk
Mask Rider Blac is offline   Reply With Quote
Old 03-07-2019, 12:05 PM   #6
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
MMT=multi mode transmission, or also a robot gear.
Its a manual gearbox with a shifter robot, a kind of automatic.
But it has gearbox oil as all other manual, but probably no filter.
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
Oil filter seeping oil from seal : Should I change it ? Hershey DIY / Maintenance / Service 33 11-14-2012 04:25 PM
First DIY oil change but... derickveliz2 DIY / Maintenance / Service 31 02-02-2009 11:36 AM
About to do my first oil change Kaotic Lazagna DIY / Maintenance / Service 32 01-15-2007 04:00 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
