Old 05-18-2014, 09:58 AM   #1
Yangs
Drives: 4 Door
Up stream o2 Oxygen sensor above 3 volts?
I test and replace o2 sensor before on other cars but this time with my Yaris I have a very bizarre situation. While the car is fully warm in operation temperature According to my multimeter, it show's little above 3.00 volts and it doesn't fluctuate from 0 volt to 3.00..."a steady voltage" I try to give it some gas but it still doesn't fluctuate. What's very strange is that the instrument cluster does NOT throw any trouble code and even thou I stick in a diagnostic scan tool it doesn't show any trouble code and emission status are good. Not to mention MY GAS MILEAGE WENT GARBAGE!!! I never heard 3 volts before on a o2 sensor. Maybe Toyota did some thing different from other car manufactures or maybe I have a bad o2 or a short some where?
Also the down stream o2 sensor read 0 volts at idle.
Yangs is offline   Reply With Quote
Old 05-18-2014, 10:42 AM   #2
With the sensors used on the Yaris the voltage is kept constant and the ECM measures the current required to maintain the voltage, so you can not use a volt meter to troubleshoot them other than seeing if they are completely dead.
Old 05-18-2014, 01:37 PM   #3
Yangs
Drives: 4 Door
thanks for the info!!!
Old 05-19-2014, 09:33 PM   #4
Yangs
Drives: 4 Door
i notice its not a o2 narrowband sensor. its actually an air/fuel wideband sensor. im surprise.
Old 05-19-2014, 09:47 PM   #5
Correct. The downstream one is a normal 02 sensor, but it too is operated in a current control mode.
Old 05-19-2014, 09:53 PM   #6
Yangs
Drives: 4 Door
im really dumbfounded about it. i though i was going nuts. i got my yaris 2 years ago. im new to the toyota world.
Old 12-16-2017, 02:39 AM   #7
ojeysky
Drives: Sedan Yaris 2010
Am seeing this same reading on my scanner. The upstream sensor reads between 3 and 3.3 while downstream reads between 0 and 0.9. From what I read here it seem it's a normal behavior? as I had thought both were supposed to read between 0 and 0.9 so I was quite concerned as well.
Thanks
ojeysky is offline   Reply With Quote
