11-04-2017, 09:53 AM | #37 | |
Drives: 2007 2-door hatchback Join Date: Jul 2016
Toyota Yaris serpentine belt tighten tension
11-06-2017, 05:35 PM | #38 |
Drives: Yaris Join Date: Oct 2017
I fixed mine over the weekend. Just loosened both the top and bottom bolts, used a prybar wiith one hand and re-tightened with the other pulling it as hard I could and done.
No more squeaky belt. |
11-07-2017, 09:32 AM | #39 |
Serpentine belt tension adjustment Toyota Yaris
Overtightening a serpentine belt destroys driven components and idler bearings.
11-08-2017, 10:17 AM | #40 |
Drives: 2010 yaris rs manual Join Date: Nov 2017
The A/C compressor was change like a year ago. It chirps or squeals occasionally when at startup and when the A/C is turned on it chirps as well. There are times when i startup, leave the car running for 60 seconds and then turn the A/C on and I get no squeal. It is suppose to get look at within the coming weeks, so hopefully i would get the problem fixed.
11-08-2017, 11:39 AM | #41 |
Mine has been quite since.
11-08-2017, 11:55 AM | #42 |
Drives: 07 Yaris Hatch Join Date: Aug 2017
As soon as I went to the Scion 100 amp alternator, mine has quit squealing. The Scion alternator uses a de-coupler pulley, so I think that has something to do with it.
11-08-2017, 05:26 PM | #43 |
Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
Check out this 'interesting' video...
https://www.youtube.com/watch?v=HRrVMtyIqIY When I first got my car, it squealed badly, partially because the previous owner put belt dressing on it. I can confirm that delaying ignition does work, at least for belts that squeak when the engine is first started. It did on mine anyway.
Similar Threads | ||||
yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 01:05 AM |
Squealing Belt | rossman | DIY / Maintenance / Service | 8 | 01-31-2012 01:58 PM |
Supercharger Belt Slip Possible fix | quemoto | Forced Induction Forum | 20 | 03-04-2011 02:55 PM |
2010 Prius brake problems easy fix. best video ever! | dinamix | Off-topic / Other Cars / Everything else Discussions | 6 | 03-14-2010 11:00 PM |
Easy Defrost A/c running fix | billk | General Yaris / Vitz Discussion | 14 | 01-16-2009 08:53 PM |
