Old 08-04-2023, 04:18 PM   #1
rajee
Drives: Yaris I
Trunk inside light removal.
Hiiy Folks,
A happy Yaris owner here.
I have a TOYOTA Yaris II Hatchback (XP9) (01.2005-12.2014).
Recently two times in a year I had this situation.
Normally I close trunk door with average force
And sometimes it doesn't close completely and
A small light was ON all the time.
Two times my battery was drained due to that
And I then my friend need to come to aid.
My question is I really don't use that light and I
Don't want to worry about this battery drain matter in future.
Can I just remove the bulb from holder and be tention free.
Or should I do anything after removing the bulb.
Or any suggestions.
Thanks in advance.
rajee is offline   Reply With Quote
Old 08-04-2023, 06:11 PM   #2
Just remove the bulb.
Old 08-06-2023, 01:00 AM   #3
sh0rtlife
if your looking for a blanking plate, the hatchbacks have a blank plate on the center of the hatch that just so happens to be the EXACT size of the light unit...in other words you can use that plate to blank your light or you can do some work and put a light where the blank plate is.....seems to be a common part across the scion line too
Old 08-10-2023, 01:06 AM   #4
CrimsonEclipse
Drives: .
Got a part number?
CrimsonEclipse is offline   Reply With Quote
Old 08-10-2023, 07:01 PM   #5
sh0rtlife
nope but you could pull yours and get a part number
Tags
trunk, trunk light, trunk release
Alternator Diagnosis, Removal, Rebuild, and Installation Guide IndestructibleYaris DIY / Maintenance / Service 2 02-25-2022 03:07 PM
Battery Light Flickering over 3k rpm 07GOKRT General Yaris / Vitz Discussion 6 11-25-2017 08:49 PM
Toyota yaris 2008 trunk indicator Joshmz DIY / Maintenance / Service 1 11-16-2017 07:16 PM
LED'n it out (warning...big pics) custom Lftback Photo-Video-Media Gallery 9 05-24-2010 03:41 AM
Intermittent low oil pressure light. Inspector14 DIY / Maintenance / Service 23 03-29-2010 01:46 PM
