06-10-2018, 12:37 AM | #1 |
Drives: 2015 yaris hatchback Join Date: Jan 2018
DRL disable
how do i disable the DRLs on a 2015 Yaris Hatchback LE? I viewed the 2007 yaris video but no luck. I removed and checked under the steering wheel assembly towards the stereo but nothing. The fuse wont budge at all.
06-10-2018, 03:14 AM | #2 | |
Drives: 2012 Toyota Yaris 1.3 -3rd Gen Join Date: Aug 2017
Sent from my SM-N910F using Tapatalk |
06-10-2018, 08:02 AM | #3 |
There are no DRL fuse.
Sent from my ONE A2005 using Tapatalk |
06-10-2018, 08:06 AM | #4 |
06-10-2018, 08:13 AM | #5 | |
2015 DRL module might be located elsewhere as the interior was completely redesigned. Sent from my ONE A2005 using Tapatalk |
06-10-2018, 09:06 AM | #6 |
why would you disable the DLRs?
06-10-2018, 09:11 AM | #7 |
I did not. I had them rewired to the fog lamps.
It's technically not legal where I live, but cops don't know. Sent from my ONE A2005 using Tapatalk |
06-10-2018, 11:31 AM | #8 | |
or get the stalk that has the foglamp switch on it and tap your headlight harness. and or look for your connectors I think the yaris is either prewired or can be wired dont ask me how. |
06-10-2018, 11:58 AM | #9 | |
Turn on the headlights, and fogs turn on or off as it should, and turn off automatically on high beam. Sent from my ONE A2005 using Tapatalk |
06-10-2018, 04:11 PM | #10 |
yeah so why did you disable the DLR's again.
06-10-2018, 04:15 PM | #11 |
Not disabled. It's always running as it should, cept they are on the fogs instead of low beam.
06-11-2018, 09:42 AM | #12 |
method doesnt work on mine. once i release the handbrake, drl lights come back on.
Similar Threads | ||||
Disable DRL on 2012 Yaris Le | ucsmfu | Third Gen Yaris General Discussion | 12 | 09-16-2015 10:29 PM |
enable DRL at Yaris 2009-2011 | Ot_tO | DIY / Maintenance / Service | 6 | 06-15-2012 05:13 PM |
08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 10:59 PM |
HID flickering problem - DRL fog - Problem solved. | IllusionX | Cosmetic Modifications (Exterior/Interior) | 9 | 10-01-2009 06:37 PM |
Disable DRL and keep Fog Light function!! | chino_potato | DIY / Maintenance / Service | 10 | 06-23-2007 01:01 PM |
