Old 09-08-2017, 06:20 PM   #1
GibbsYaris07
Drives: 2007 Toyota Yaris 3dr
Wires for reverse light bulb
I'm trying to install this reverse camera and I have the wires ready however I don't know which wires are for the reverse bulbs to splice in. I have a picture of the wire set for rear bulbs. Can someone tell me the + and - wires for the reverse.
The Gibbs Garage
2014 Lexus IS350 f-sport (my fun car)
2013 Lexus RX350 (wife's vehicle)
2007 Toyota Yaris 2dr Hatchback (my commuter)
GibbsYaris07 is offline   Reply With Quote
Old 09-09-2017, 08:07 PM   #2
GibbsYaris07
anyone can help?
The Gibbs Garage
Old 09-09-2017, 09:10 PM   #3
Whiplash
Drives: 2009 Yaris 4DR
Can you tell by looking in the trunk?
Whiplash is offline   Reply With Quote
Old 09-10-2017, 03:44 AM   #4
What I did was looked at the reverse bulbs, looked at its wire connector, and guess (correctly) on which wire was positive and which was negative (had a black stripe on it iirc, whereas the positive was a solid color that I can't remember).
Also, gotta make sure you connect your HU's trip wire as well (I'll be doing that tomorrow as right now I have to manually turn on the camera once I'm in reverse)
http://www.yarisworld.com/forums/sho...3&postcount=10
Old 09-10-2017, 09:25 AM   #5
GibbsYaris07
I think I going to skip installing the reverse camera. I really don't need on for this tiny car anyway. lol
The Gibbs Garage
Old 09-10-2017, 12:05 PM   #6
Whiplash
You can also look for wires around the shifter if that's easier.
Old 10-30-2018, 06:10 PM   #7
2007YarisBase
Drives: 2007 Yaris Base
Reverse Wire
Of the five wires on the rear light harness, did you figure out which is the correct wire?
TIA
2007YarisBase is offline   Reply With Quote
Old 02-01-2019, 11:02 PM   #8
GibbsYaris07
nope, I tried all the wiring and it still didn't work. For this little ass car, its more trouble than its worth so I said f*** it and abandoned this install.
The Gibbs Garage
Old 02-02-2019, 10:59 AM   #9
myfirstyota
3 Yaris and counting..
Drives: 07 Yaris rs 3 door 2zr swaped
In my 2008 3 door, it's the brown (I think, my eyes kinda suck with colours)
Where the yellow wire enters the connector is the spot for reverse positive.
You can see the shrink wrap where I already made the mistake hahah.
I turned the reverse light into a diy rear fog light. That's why I have the yellow wire re-pinned into the connector where the reverse positive goes.
No one suspects the Yaris.
Xd/2zr-fe Swap/Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61427
Bolt-in 3.75" Suspension Lift Build Thread
http://www.yarisworld.com/forums/showthread.php?t=61577
myfirstyota is offline   Reply With Quote
Old 02-07-2019, 09:39 AM   #10
GibbsYaris07
tried that one and it didn't work.
The Gibbs Garage
Old 02-07-2019, 12:31 PM   #11
myfirstyota
Can't help you them bro. That's the one on my car.
Light Bulb Specs? Violin DIY / Maintenance / Service 34 12-06-2018 06:09 PM
Wires Inside the Yaris & What They Do The Architect DIY / Maintenance / Service 147 03-17-2018 07:00 PM
03 Yaris Dome light help GoldenMonkey93 DIY / Maintenance / Service 6 11-13-2014 04:06 PM
Changing Map Light Bulb justin27zamora DIY / Maintenance / Service 2 06-19-2013 11:07 AM
How many forum posters does it take to change a light bulb? silver_echo Off-topic / Other Cars / Everything else Discussions 25 06-27-2011 01:50 AM
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
