08-25-2019, 07:33 PM | #73 |
Drives: 2009 yaris Join Date: Feb 2016
Yay! 48.3 mpg highway, light throttle 60-68mph.... loving these cheap plugs!
10-28-2019, 06:35 PM | #74 |
147K-Blue / 24K-Yellow
Drives: 2010 Ylw 3dr. AT(Blue-Wife's) Join Date: Mar 2011
Update on Anti-Seize
Well then, I have some "Updating" of my own...It was found incorrect to depend on NGK’s "trivalent coating" and not using anti-seize (my mechanic friends joke as “irrelevant coating”). It has been discovered in the mechanic world that it isn't as good for corrosion/seizure protection as once thought, especially on subsequent (after first factory installation) new plug installations, as can be seen in many of the removed plug photos you will have carbon in the plug and head threads, and that can/will cause seizure of the plug, if you don’t clean it off (not recommended as you dump that crap down on top of the piston and it can damage the cylinder walls) or add a small amount of anti-seize and torque them to the proper “lubed” torque spec. After the steel “coated” but not anti-seized plug has been installed and heated thousands of times in an aluminum head, and that heating/cooling causes the plug to microscopically “walk” in the head due to the dissimilar metal’s expansion rates, creating a carbon grinding action, which breaks down the coating, and allows corrosion of causes seizure. The plug manufacturers don’t want you to use anti-seize because not many people know how to de-rate the torque spec for installing the plugs. However, there are automotive manufactures that DO recommend using anti-seize, regardless of the plug mfr’s recommendations.
Just what I have learned from the Automotive and in the Power-Sports world, in the last 8 years… I have always used Anti-Seize as taught to at the small engine mechanic shop I grew up in, but it was more a personal preference thing. (I even use it on lug nuts and other long-term attachments, never had a problem, EVER.) I also change my plugs long before the 100,000 mile recommendation.
All Weather Package, Power Package, Cruise, WeatherTech Floor Mats. Altimax Arctic Winter Tires. Repair List: 1 new blower motor, making funny noise. @ 91K (Water pump @ 120K) Mod List: 1. Black tape on most of the annoying blue high beam light behind the lens. (thank you CTScott) |
11-03-2019, 02:01 PM | #75 |
Drives: 2009 Base Hatch 2 Dr Auto Join Date: Dec 2008
The plugs went 150,000 miles in my wife’s Camry. The new ones didn’t make it run any better the old ones work just fine.
The accessory belt and 150,000 miles on it also before I change it. The gauge I got said it was not worn at all. I could nt Bear to throw it out.
11-04-2019, 05:20 PM | #76 |
I have found going longer distances on plugs causes other problems that may or may not be apparent right away... In the old days it would burn rotor and cap due to excessive secondary resistance...NOW it causes coil packs to get hot and burn out, due to excessive secondary resistance...
I always keep the old belt in the back (along with a few tools to do the emergency change) but once they start drying out/squealing/cracking...time to kick it out, I would rather NOT have it crap out along side the road, because I was too cheap/lazy to do preventative maint.
11-05-2019, 08:28 PM | #77 |
Drives: 2007 Yaris Hatch Join Date: Feb 2007
I have never had an issue not using anti-seize on plugs. My Yaris has 300k on it. I'm on my 2nd set of Denso Iridium power plugs. Oem plugs I took out at 100k. Installed the first set of Denso's and took them out at 200k. No seizures yet. I've not used anti-seize once since my first spark plug job in 1992. Not one seizure on many of my platforms, 80's rx-7's, 90's rx-7,s, 90's supra, 90's Landcruiser, 90's Toyota pickups, 90's dsm's, 2006 merc amg's, mitsu gvr4's, Cressida, 90's skyline gtr, Lancia Integrale, 2004 Mitsu Evo, the list goes on. You do not need it. It also reduces the sparkplug grounding connection.
05-13-2020, 05:50 PM | #78 |
Well, To each their own.
I have been using anti-seize on plugs for 35 years, and have had ZERO problems, I would strongly disagree with the theory that it inhibits grounding of the plugs...My Ohm Meter also disagrees. I am just stating what works well for me... And Preventative Maintenance is better than a tow bill.
05-14-2020, 02:35 PM | #79 | |
Drives: No longer own a yaris :( Join Date: Mar 2012
Just hit 175k miles on my original plugs. Car still seems to drive the same and get the same gas mileage so I haven't bothered changing them.
I'm a hermit named Lee |
08-08-2021, 11:40 AM | #80 |
Drives: VERSO S Join Date: Jul 2021
I am in same dilemma
I have DENSO SC16HR11 https://www.yarisworld.com/forums/sh...ad.php?t=63470 Looking to replace I viewed with techstream misfire on cylinder 1 IS NGK is better than DENSO ? |
08-09-2021, 08:08 AM | #81 |
I changed the spark plugs on my wife’s 2005 Camry at 150,000 miles and they looked perfect in the car ran perfect also. I think it was $40 for the iridium plugs.
Totally unnecessaryIn my opinion. But I would recommend removing the plugs so they don’t become seized. I would say 50,000 miles to remove and reinstall plugs is a good idea. I think I also put anti-seize on the new plugs I put in. If the plugs seas and you stripped them removing them that wouldn’t be good.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Pics Pics Pics | Jahbs | Australia | 4 | 06-30-2010 12:06 PM |
HELLAFLUSH III pics | contraband831 | Photo-Video-Media Gallery | 37 | 01-10-2010 12:11 AM |
Oh I am so mad my dealership had the wrong gap on my plugs | joeharth | Fuel Economy Forum | 10 | 03-25-2009 05:26 PM |
sparco seats and pedals (pics) | turboyaris | Cosmetic Modifications (Exterior/Interior) | 18 | 09-05-2007 02:43 AM |
Extra parts? (Or where do these plugs go) | jah | General Yaris / Vitz Discussion | 6 | 05-01-2006 10:33 PM |
