12-01-2008, 09:49 PM | #1 |
Official HID show off
I remember there was this thread about the glare of HID in a reflector headlight housing. Well, i finally had time, and it was actually dark enough to take good pictures of my headlights...
the kit... i'm using 1 volvo ballast and 1 maxima ballast lol. The bulbs are BMW bi-xenon bulbs modified to fit in a H4-2 solenoid. Anyways.... 4300k power. Last edited by IllusionX; 12-02-2008 at 08:09 AM. |
12-02-2008, 01:20 AM | #2 |
Drives: '14 GT86, '08 Vitz Join Date: Dec 2006
LOOKS WAAAAY BETTER THAN MY CUTOFF.
12-02-2008, 05:50 AM | #3 |
HID crew what temp? mine are 6000k but those look to be a little bit more blue than mine.
12-02-2008, 08:08 AM | #4 |
4300k the same bulbs found in a BMW 330i or X5.
12-02-2008, 05:06 PM | #5 |
I want some 5500k bulbs. My 6000k's are a little too blue for me.
12-03-2008, 01:54 AM | #6 |
Drives: 2008 Yaris Sedan Join Date: Oct 2008
12-06-2008, 10:56 AM | #7 |
With retrofitted RX-330 projectors and clear lens swap.
12-06-2008, 12:34 PM | #8 |
I suck. I've still got my retrofit sitting in my closet.
12-06-2008, 05:09 PM | #9 |
You do suck.
12-06-2008, 05:30 PM | #10 |
rice rocket
Drives: 05 Echo Join Date: Feb 2007
i've had my retrofit stuff sitting in my basement for 2 years, but at least i put them in a few months ago :P
12-07-2008, 02:02 AM | #11 |
i have some bimmer auto adjusting projectors somewhere... gonna fit them in this summer...
12-15-2008, 02:48 AM | #12 | |
The Fit is NO!
Drives: '09 3DR "S"|'87 Caddy Brougham Join Date: Dec 2008
If there is a way to do that, PLEAAASSSEEEE post pics and instructions and video. if you get auto leveling, adaptive lights working on yaris, I you!!!!!
My OTHER car Please ignore the Ferrari |
12-15-2008, 08:06 PM | #13 |
well, the feature is there... but i don't have anything else.. so, i doubt it'll get everything working as it's supposed to.
12-16-2008, 02:42 AM | #14 |
rice rocket
i don't think you'll get too far with auto-levelling without significant work. The auto levelling feature relies on a bunch of sensors and the ECU to do its job for cars that come with it, and having only the parts from the headlights is not enough.
i'm guessing you just have the headlights so you'll just have the motors which are not much use unless they can be manually adjusted like the FX projector motors. But with that, making a mounting mechanism to allow it to pivot and adjust will take some time and thought.
12-19-2008, 08:12 PM | #15 |
Drives: HONDA Join Date: Oct 2008
Here are a few pictures from our customer from YARISWORLD
12-20-2008, 04:45 AM | #16 |
Wow Violin very nice as I remember. Lets not get into the subject of glare and cut off and if you need a harness with relays :). I know I had some HID's and I was blinding people. Felt so bad I ripped them out.
12-20-2008, 10:10 AM | #17 |
I had a DIY posted before the hack. I'll have to put something together.
I made a harness (actually two so if one fails, I still have the other side) that lets me flash the highs without the HIDs (lows) coming on. The lows stay on when I turn on the high beams so my ballasts aren't cycling on and off. |
12-20-2008, 10:24 AM | #18 |
oh, did i mention that my HIDs are bi-xenons? got this actuator that changes the position of the bulb for high beam.
Similar Threads | ||||
DIY - HID Retrofit | Violin | DIY / Maintenance / Service | 57 | 06-11-2007 06:17 PM |
HID worth It? | jamal1984 | Performance Modifications | 6 | 01-31-2007 03:42 AM |
KLight HID Conversion Group Buy!! $165.00 shipped!! | JRT lighting | Sponsors Classifieds Area | 4 | 11-20-2006 10:47 PM |
