Old 12-21-2008, 01:12 AM   #19
slvryaris
slvryaris's Avatar
Drives: 2007 Yaris Sedan S
Thanks Violin. What plugs and part number and manufacturer did you go with? I have been reading about if NGK or Denso plugs are better. I am going to order some but just don't know which ones to get. O reilly pulled up the NGK Iridium IX BKR5EIX is what came up for the Yaris, but they couldn't get the Denso.
Old 12-21-2008, 08:47 AM   #20
slvryaris
slvryaris's Avatar
Thats weird....The NGK plug our manual shows as OEM is IFR5A11 is not found on www.sparkplugs.com it is IFR5T11. I wonder if these are the same. Advanced Auto Parts shows they have these for $6.99.
Then the Denso plug SK16R11 just shows as a Iridium Long Life plug and shows the
PK16R11 as the OEM equivalent and its not even iridium tip.
Old 12-21-2008, 09:44 AM   #21
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
The NGK BKR5EIX is not the long-life version. The Denso PK16R11 is a platinum plug.
I went with the Denso SK16R11 from sparkplugs.com.
Old 12-21-2008, 10:41 AM   #22
auxmike
auxmike's Avatar
When I'm ready for plugs I'm going straight to the dealer's parts desk!
Old 12-21-2008, 07:38 PM   #23
Violin
Violin's Avatar
Be prepared to pay $14 per plug.
Old 12-21-2008, 08:29 PM   #24
auxmike
auxmike's Avatar
I'll be shopping at an internet dealers "parts counter"!
I've found they are usually MUCH cheaper......!
Old 12-21-2008, 11:36 PM   #25
slvryaris
slvryaris's Avatar
Denso at the dealer I called were $21 a piece. Since the SK Denso's are gapped at .044 that means they will not need to be gapped since that is 1.1mm is that correct??
I guess the NGK number is IFR5T11 now. From what it said on Advanced website the NGK had a 3 year warranty and Denso said 3 month. Can anyone interject on which brand is better? They are both Laser Iridium Long Life plugs.
Old 12-23-2008, 04:40 PM   #26
slvryaris
slvryaris's Avatar
The NGK plugs I got were the IFR5T11 which I am guessing is the IFR5A11 but a different number since it says they are the OEM replacement.
The only problem is the NGK plug is gapped at .032 sooooo I am guessing I need to widen the gap on these puppies. Some of the guys at Advanced said I shouldnt gap them since they are Iridium plugs, but the service manual says new plugs should be .039 to .043 in.
So in theory I should widen this gap?? Also why does on www.sparkplugs.com show that the OE gap is .032 but when you highlight the product to the right of it is a picture of the plug and the specs on it and then at the bottom of the specs it says .044" (1.1mm) Gap
Extreme Long Life Laser Iridium Plug, 14mm Thread, 19mm (3/4") Reach, 5/8" (16mm) Hex Size, Gasket Seat, Resistor, Solid Terminal, Projected Tip, Iridium Tipped Fine Wire Center Electrode with Platinum Tipped Ground Electrode, .044" (1.1mm) Gap
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
Viper Alarm Install gwasabi In Car Entertainment + Electronics (audio / video / alarm) 28 08-11-2010 02:57 PM
Toyota AUX plug w/ aftermarket radio? eight_heads In Car Entertainment + Electronics (audio / video / alarm) 20 09-07-2007 02:41 AM
Bujias?¿ Normales o otras? Fer.pa Central and South America 12 07-13-2007 03:46 PM
Oil Drain Plug Size? Nigal DIY / Maintenance / Service 4 05-31-2007 01:55 PM
