![]() Drives: 2016 Yaris LE Join Date: Mar 2018
Bumper end pops out
2016 Yaris LE. Any suggestions on fixing an issue where the bumper end pops out when jarred (passenger side only). I pulled it out to demonstrate the extreme case.
My Yaris is a taxi
Drives: 5 Yaris Hatchbacks Join Date: Jul 2016
If it's under warranty have it fixed for free. Otherwise try replacing the clip on the fender or just glue it in.
-Karl the Uber/Lyft Driver |
![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
Glued it. Hopefully it will hold up.
https://www.jbweld.com/collections/e...bonder-syringe Last edited by agent86; 03-29-2018 at 09:06 AM. |
![]() Drives: 2012 Yaris 3d LB Join Date: Feb 2017
My 2012 yaris has the same problem on the the passenger side too. Although, it is not as pronounced as yours. I usually just pop it back into place, but after awhile it pops back out.
Never thought about using those passwordjdm quick release to keep it secure. May try that if it gets worse. |
2ZR swap. DO IT! Ask how!
I hope you don't need to do any work on the front end, like replacing a headlight. There isn't enough room behind the headlight body to pull the main bulb. You really need to remove the bumper fascia to remove the lens assembly. I ended up getting new clips for mine, but I've taken the front end apart probably 20 times since I've bought it for one reason or another. The bumper itself is also worn, so that's part of the problem. I have dreams of upgrading the '09 to the '12 or '15 cosmetic upgrade when I've got a spare $1k laying around. =)
![]() ![]() ![]() ![]() ![]() ![]() Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
The 3rd gen does not have the same space constraints as the 2nd gen and can be done without the hassle of popping the bumper cover and removing the light assembly.
Tags |
bumper joint retainer |
Thread Tools | |
Display Modes | |
FS: Full NCP91 KavinT Manseth Kit (Front Bumper has Damage) | Treyz | Items for Sale by private party | 22 | 04-08-2014 06:17 PM |
Rear bumper partial detachment caused by wind | D-Flo | DIY / Maintenance / Service | 3 | 11-21-2013 07:15 PM |
FS: JDM Vitz RS Front (2009) and Rear (2007) Bumper (AZ and Possibly So Cal) | jmew0ng | Items for Sale by private party | 23 | 10-05-2013 12:24 AM |
New Bumper Cover | CB900F2 | DIY / Maintenance / Service | 6 | 01-18-2010 07:49 PM |
2009 Front Bumper Conversion with foglight | 808yarisLB | Cosmetic Modifications (Exterior/Interior) | 25 | 01-03-2009 01:47 AM |
