Old 04-10-2018, 04:02 PM   #1
twiceover
Drives: 2007 Nautical Blue Yaris Sedan
2007 Yaris Integrated to Double DIN. What do I need?
I have a 2007 Yaris Sedan that came with the integrated radio. I want to remove that and upgrade to a double din unit, probably some Android Auto Pioneer unit or something.
I know I need the dash trim kit for the double din opening, and possibly spacer kit. Wire harnesses etc. What I'm wondering really is what do I need in order to mount the aftermarket radio into the opening? I have found single din kits that appear to replace the factory double din, but no bracket to go from the integrated to double din aftermarket. Is the bracket already there and attached to the factory radio?
Thanks in advance. Wife just got a 4Runner and now I'm super jealous and want to upgrade at least my stereo.
twiceover is offline   Reply With Quote
Old 04-10-2018, 04:53 PM   #2
You need the non-integrated bezel piece. Part# 55405-52640.
Search here using that part# and you will find threads were swap was performed.
Old 04-10-2018, 05:07 PM   #3
twiceover
Thanks, I did find a thread that states to use the mounting bracket from the factory stereo. I think that's what I need!
EDIT: It's really unfortunate that every thread the pictures are long since gone. :(
Old 04-24-2018, 06:51 AM   #4
Guinness
Drives: 2018 Yaris Hatchback SE
I replaced my radio in my 07 when I bought it, but that was 4 years ago. I should look for a tutorial as there was one with pictures. Maybe I just printed one out from here. I believe the stock radio does have brackets along the side to mount the new radio. I replaced it with a double din though. I even removed a lot of the dash to run the wire for the microphone under the steering wheel.
Guinness is offline   Reply With Quote
Old 04-24-2018, 09:02 AM   #5
Guinness
I found this. Looks like you might need a bracket that should come with the stereo. There are 4 videos in the series:
https://m.youtube.com/watch?v=_wvC7JtnAGM
Old 05-07-2018, 08:52 AM   #6
oldguy07himile
Drives: 168k Miles 07 yaris
FWIW I just replaced mine this weekend with a double din JVC unit, it was shockingly easy to reuse the factory brackets. I got a bit hung up on the install as there were three connections in the old stereo and only two connections to the new unit. I have to assume they were for the CD player as I installed a unit sans CD player it didn’t seem to matter. I have 100% functionality and all seems to work. Good luck
oldguy07himile is offline   Reply With Quote
FS: Yaris Double din Face Plate Tank Items for Sale by private party 11 03-05-2011 02:17 PM
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW VitzBoy General Yaris / Vitz Discussion 5 09-05-2010 08:53 PM
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
