Old 02-24-2017, 12:44 PM   #1
Stevengr921
The BodyArchitect
Drives: Yaris Sedan 2015 Turbo AT
REAR LEFT FENDER ISSUE
so i bought some m2 lowering springs for my yaris and all of them seam to work nicely they droped 1,5" of height i can barely get 2 fingers in each fender except the rear left which i just can fit 1 finger and it touches the wheel , so i checked under the car and the springs look exactly the same compressed but i don't get why is it lower in that fender? ,so a friend told me its a "yaris thing" that he has seen many others lowered with the same problem no matter the lowering springs (eibach,H&R,tein,m2,manzo,megan) so i want to know if this is true and are there any solutions for it?
thanks
Stevengr921 is offline   Reply With Quote
Old 02-24-2017, 03:53 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
I have heard of this before. The rear axle I think is offset a bit for some reason.
Old 02-25-2017, 06:13 AM   #3
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
yup. my spring perches are of uneven height to balance it out. And also you may notice one wheel will be more flush and will have to use one extra wheel shim just a tiny bit.
Check out my Build thread:
Old 02-25-2017, 10:55 AM   #4
Stevengr921
The BodyArchitect
So there's no actual solution? �� I'll have to stretch my fender then so it can fit and stop touching the wheel
Old 02-26-2017, 11:40 AM   #5
SirDigby
Drives: 2007 yaris 3 door
that sucks. i'm glad I came across this information. I would think your only solution would be to roll fender, or to buy adjustable coilovers. I now know not to buy springs.
thanks!
Old 02-27-2017, 03:48 PM   #6
jra
Drives: 2015 yaris L
I would be more interested in having more ground clearance so my wife doesn't keep hitting curbs with bottom of bumper when parking.
jra is offline   Reply With Quote
Old 02-28-2017, 09:32 PM   #7
Stevengr921
The BodyArchitect
thanks!
From what if heard and experienced in other cars coil overs make the car jump a lot but it does give the lowered look and stability you need
Old 02-28-2017, 09:34 PM   #8
Stevengr921
The BodyArchitect
Haha they get used to it eventually
Tags
help!, issue, lowering springs
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 53 11-12-2017 03:03 PM
e46 rear shock issue Caramanos2000 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 05-19-2015 09:04 AM
Original tail light without rear fog light for Yaris 3dr 2009-2011 Ot_tO Cosmetic Modifications (Exterior/Interior) 9 08-07-2012 04:27 PM
