Old 05-17-2017, 11:49 AM   #19
hotracer_05
Hmm, I see...
hotracer_05's Avatar
Drives: 2012 Toyota Tundra and Yaris
I managed to fit a full size spare in the back of my 2012 Hatch, but the hybrids might have a different size
Originally Posted by hotracer_05 View Post
One of the original tires was in decent shape, and since i bought the car without a spare i decided to just use it (not a fan of doughnuts anyways). The full size tire wont fit where the old spare goes without removing the riser piece on the top. This is tac welded to the car, so before doing this you need to make sure you don't have any emotional attachments to that doughnut. I simple took a big hammer and beat it out...but you can definitely grind away the tac welds. then simply fill the holes in and ta da! full size spare room
"Everything happens for a reason. Sometimes that reason is you're and idiot"
hotracer_05 is offline   Reply With Quote
Old 05-17-2017, 11:51 AM   #20
hotracer_05
Hmm, I see...
its a 15" wheel, tire is a 175/65r15 i believe
Old 05-17-2017, 12:31 PM   #21
dogsridewith
Drives: 2007 2-door hatchback
Spare tire well riser removal
! I've puzzled over that thing...what it does and how to remove (for flat seat-deleted floor when 14" mini-spare goes on the front "bumper." )Did you hit a chisel between it and the pan where the spot welds are? Or just wack the riser itself? The holes shown in photos result, w/ no drilling involved?
Old 05-17-2017, 01:09 PM   #22
hotracer_05
Hmm, I see...
I would recommend a Chisel...but i didn't have one in my hand so i just whacked and patched after lol. The holes are where the welds where. I didn't drill them out
Old 05-17-2017, 02:13 PM   #23
dogsridewith
Might work w/ a ball-ish stone in a die grinder working down through just the riser piece at the spot welds. Then should be easy to knock it off and clean up pan w/ no holes?
(prolly easier than removing wheel cover anti-rotate keys on wheels that are never going to see a full cover...my Yaris doesn't have, but circa 1990 Miata and Corolla do.)
Old 05-17-2017, 02:44 PM   #24
hotracer_05
Hmm, I see...
It could, i filled the holes in after and sprayed the whole spare tire well with rubber coating
Old 07-01-2017, 12:25 PM   #25
funky2nite
Drives: 2013 Hybrid 1.5L T4
As a quick update, i tracked down a 15inch full size wheel. I think it belonged to an older peugeot. It did it fit in the boot, yey since its not a space saver it atuck a bit higher up than the wheel hole so i lost some luggage space..but space saver wheels i found didn't fit due to hybrid having disc brakes on the rear. http://imgur.com/a/s4TPY
funky2nite is offline   Reply With Quote
Old 07-01-2017, 12:33 PM   #26
funky2nite
I did notice that the bit you guys had to grind off/remove seemed missing already in mine.
http://imgur.com/a/Jo2ul
Old 07-02-2017, 10:02 AM   #27
Yaris709
Drives: 07 yaris
I use a full size spare tire. Bit larger than a dummy tire but if I get a flat I can just throw it on and go with no worries.
Yaris709 is offline   Reply With Quote
Old 07-02-2017, 12:31 PM   #28
funky2nite
Good stuff, but its either the tire size i picked or dunno cos fromwhat ive. Read through other posts no one mentioned losing vertical space when fitting full sizw wheel. That isnt a plus with me, in fact i ended up removing thr parcel shelf
Old 12-10-2018, 09:51 AM   #29
dogsridewith
Yaris tower in spare tire well
Re-considering, I might first try through-drilling the spot welds w/ a 3/16 bit so that if it then chisels off cleanly, the tower can be easily re-installed with pop-rivets. Noting not to let the drill go deeper than required to get through the sheet metal...there's car parts under there.
(Wouldn't happen until the mini-spare is on the front "bumper")
Old 12-10-2018, 10:22 AM   #30
DarkShadowFox
Drives: 2015 Yaris LE 3door 1F7
COOL now time to do this. good thing the entire car is some form of steel. and not aluminum.
DarkShadowFox is offline   Reply With Quote
Changing to an MR2 Roadster Steering wheel MESSIAH DIY / Maintenance / Service 2 05-03-2015 12:02 PM
Black/Grey OEM Leather Steering wheel question heeroyuy01195 Cosmetic Modifications (Exterior/Interior) 12 10-14-2011 01:22 AM
Wheel Well Question gwasabi Cosmetic Modifications (Exterior/Interior) 3 04-15-2009 12:09 PM
Question about wheel Offset monoculusjoe Wheels, Tires and Suspension Forum sponsored by The Tire Rack 9 09-07-2006 03:03 AM
Wheel and tire question. EddyCocaine Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 08-31-2006 11:13 AM
