04-25-2009, 08:15 PM | #1 |
Drives: 2008 Liftback Join Date: Mar 2009
Just finished DIY NF210 but have question about the gap ....
Hi,
I just finished installing NF210 but i have about 1/4" space between the top cap and car body (top of the strut tower). Is this a problem? Thanks Pat |
04-25-2009, 08:18 PM | #2 |
Put up a pic. I think this is something that many have questioned, and seems to be normal.
04-25-2009, 08:32 PM | #3 |
Got the pic but can't figure how to put in this thread.
Thanks |
04-25-2009, 08:33 PM | #4 | |
Start another Oil Thread!
04-25-2009, 08:34 PM | #5 |
I attached the pic.
04-25-2009, 08:36 PM | #6 |
Yep, looks like what others have reported.
04-25-2009, 08:38 PM | #7 |
I Just don't see how this can be OK.
The strut assembly is not really bolt on to the car if there is this gap there. ??? Last edited by 350zrb; 04-25-2009 at 09:04 PM. |
04-25-2009, 09:54 PM | #8 |
Looks like you may have to tighten the top of the strut mount bolt a bit.
04-25-2009, 10:06 PM | #9 |
The first nut (below the cap) is already tighten. The second nut (above the cap) also tighten and wil not go down any more.
Thk |
04-25-2009, 10:52 PM | #10 |
Drives: 2008 meteorite hatchback Join Date: Nov 2008
No, it's fine, actually. If you jack the car up, you'll notice that the gap goes away. I took my car to the local performance shop, and they said it's just the result of having lowered the car. No problem.
Btw, I'd put the little rubber cap back on if I were you...
- HOOOEY! That's one tahny little cawr! What the heck kinda toy is that? - A Toyota Yaris - A whut Yaris? |
04-25-2009, 10:52 PM | #11 |
it's been a while
Yep mine look like that too, no problems. I have trd springs
04-26-2009, 12:22 AM | #12 |
Yes, I will put the top rubber cap back on.
Thanks for info guys. |
04-26-2009, 12:29 AM | #13 |
Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
why don't mine look like that then? i have the tokico's and df210's. is it just some setups cause this gap and some don't?
04-26-2009, 12:37 AM | #14 |
What is Tokico? A strut?
I have original strut. |
04-26-2009, 12:40 AM | #15 |
04-26-2009, 12:42 AM | #16 |
Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Tokico HP shocks/struts are upgraded "performance" based to make handling stiffer. It is designed also for lowered applications. As in if you put lowering springs on, these things go great with them because they help stop the "spongey" feel and help from rubbing, etc.
04-26-2009, 12:45 AM | #17 | |
04-26-2009, 12:59 AM | #18 |
Yes, it's kind of bother me too.
I also cut the bump stop by 1.1" May be I will put in hard rubber gasket into the gap? |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
DIY Change Your Interior Light Grey Panels to Black | KCALB SIRAY | DIY / Maintenance / Service | 64 | 01-22-2015 01:25 PM |
Plug Gap | slvryaris | DIY / Maintenance / Service | 1 | 12-23-2008 10:02 PM |
Tanabe NF210 Installed - Question | spacemanoeuvres | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 07-15-2007 08:16 PM |
DIY Tacho install question | Capagotks | DIY / Maintenance / Service | 6 | 07-04-2007 04:59 AM |
