02-02-2012, 03:32 AM | #1 |
Drives: Toyota Vitz 2007 facelift Join Date: Jan 2012
Some advice req for my Yaris
Hi,
I needed some suggestions for maintaining my Yaris and would appreciate your advice please: 1. Can I was my Yaris at a service station? The area I'm interested in is the engine bay area. It gets quite dusty after some time due to the pollution and dust etc and would appreciate a clean engine bay. 2. Can I remove the catalytic converter because the quality of fuel we get here is not that good and the catalytic converter in some cars tends to get chocked over time leading to more pressure on the engine. Was just wondering if this is a good idea to remove it altogether?? 3. How often should the throttle body be cleaned for good mileage. It tends to get full of carbon deposits over time and is black. Out here the spray it with a carb cleaner. Thanks in advance Tyrone |
02-02-2012, 03:48 AM | #2 |
Drives: 2008 Yaris Sedan Join Date: Oct 2008
1 - Just 'mist' it with water. I didn't ever cover anything. I use one of these and choose the mist setting.
There is really no need to cover anything up if you use the mist setting unless you are super super paranoid about the engine dying because it touched water (it won't.) I have done it once a month now for over 2 years with not a single problem. You don't really need a degreaser or anything, just wipe it down with a towel after misting it. The Yaris engine is very strong and can take some hard abuse. Sorry, don't know about 2 or 3... |
02-02-2012, 01:04 PM | #3 |
Drives: 09 Meteoric Metallic 3 door HB Join Date: Jul 2010
I would recommend some of Garm's products at Microimageonline.com
Get a hood seal and an underpannel kit (whenever there are more in stock) and that should help keep your engine clean. Also, check out this thread for a very good way to clean your engine bay. I've used this method a few times and it works great. As for your cat, I believe you can remove it but I think will cause a check engine light to come on, unless you move the 02 sensor (This thing). You could take it to a shop and have a custom job or you could get the midpipe that Garm sells. I'm not sure what the emissions laws are where you live though, so check those first before you do anything with your catalytic converter. And i'm not sure about your throttle body, soz mate. |
02-04-2012, 12:20 PM | #4 |
Only Happy When it Rains
I say go check out the people in the Middle East forums. They can help you out with some of the cleaning and dust problems i think.
you can remove anything from your car, but i agree that you need to check your local laws to see if it is legal.
Colin Chapman disciple |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Yaris vs MR2 Spyder | regal | Off-topic / Other Cars / Everything else Discussions | 35 | 06-03-2010 06:50 PM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
New 07 Yaris S need advice on 18's and springs | OgDogg | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 48 | 04-27-2009 09:50 PM |
