Old 12-29-2013, 09:24 AM   #1
LuisPRTRD
Angry Bird
LuisPRTRD's Avatar
Drives: yaris sedan
Angry starter stuck?
Some times and mosty when its cold when I turn my yaris on the starter stays on and grins a bit for less than a second. Is my starter on its last or can this be something else?
LuisPRTRD is offline   Reply With Quote
Old 12-29-2013, 12:08 PM   #2
It could be that the starter solenoid is sticking, but most of the time when people experience long cranks the culprit ends up being that the battery is on its way out.
Old 12-29-2013, 02:02 PM   #3
LuisPRTRD
Angry Bird
LuisPRTRD's Avatar
Drives: yaris sedan
I tested my battery not to long ago when I worked for pepboys...I'll get it tested agin it's still under waranty
Old 12-29-2013, 04:58 PM   #4
Sir A.Y. Atoyot
Sir A.Y. Atoyot's Avatar
Drives: '08 5-door
Could be you're just seeing a normal cold start. The Yaris starter is designed to keep turning until the engine starts. You should turn the key to the start position and then let go immediately - if you hold it for longer it may really grind.
Sir A.Y. Atoyot is offline   Reply With Quote
Old 12-29-2013, 06:28 PM   #5
LuisPRTRD
Angry Bird
LuisPRTRD's Avatar
Drives: yaris sedan
I know and I let it go inmmediately...after I let it go the car turns on and the starter is still going it does this some times mosty when its cold
Old 12-30-2013, 10:44 PM   #6
Sir A.Y. Atoyot
Drives: '08 5-door
OK, it's probably a problem with the starter - maybe the solenoid is sticking, as CTScott suggested. If something like oil or antifreeze has been leaking into the starter, it could combine with dust to form a sticky mess that will cause the starter drive to jam. Another possible cause is the ring gear on the flywheel (the big gear that the small pinion on the starter drive engages). I have seen some really chewed up ring gears that are reluctant to let the drive retract after starting. Check for this condition by removing the starter and manually turning the engine over, examining all the teeth on the ring gear carefully. Suggestion for the next step: you should dismantle the starter for cleaning (cheap) or replace it (expensive.)
Starter sticking or ??? CueBall DIY / Maintenance / Service 4 09-07-2014 01:52 AM
Starter Kill david.gartee1 DIY / Maintenance / Service 7 03-01-2014 08:14 AM
Remote Starter - Tail Light Problem Chrsto4 General Yaris / Vitz Discussion 4 10-31-2009 11:36 PM
starter kill & horn help spechuy DIY / Maintenance / Service 0 10-20-2008 01:30 PM
Starter dragging YarisTom73 DIY / Maintenance / Service 5 08-27-2007 12:11 PM
Powered by vBulletin® Version 3.8.0
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
