Old 01-06-2014, 08:05 PM   #1
rockrabbit
Drives: Yaris Sedan '07
14mm replacement bolt on alternator?
Greetings,
Made the attempt to replace my timing belt today, but had a dickens of a time trying to get the lower 14mm bolt to come loose!
Managed to round the bolt head in the process...
Left the setup as is and began a search for the replacement 14mm bolt...
sadly I cannot seem to find a resource for this part!
any help?
rockrabbit is offline   Reply With Quote
Old 01-06-2014, 08:15 PM   #2
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
There's no timing belt on our Yaris. It is chain driven.
I think you may be referring to our drive belt. The bolt you speak of sir is the alternator lower bolt?
It is a bit of a pain to remove. What you need is a extension on your small ratchet.
Use a pipe on your 1/4 drive ratchet or maybe a small torque wrench would work.
And push ( anti clockwise) directions. You can purchase the bolt at your local toyota dealer.
Old 01-06-2014, 08:19 PM   #3
rockrabbit
I should of searched a bit more before posting, found the part code!
90105-10075
And yes, drive belt!
Old 01-09-2014, 04:19 PM   #4
esse10
Drives: 2009 yaris 2 door
new bolt
when u put the new bolt in put a little anti-seize lube on the threads for easy removal the next time you need to adjust or replace the serpentine belt. a swivel ratchet with a long handle works pretty good too.
Lower alternator bolt won't go back in, help! Tmblackflag DIY / Maintenance / Service 3 01-21-2013 03:18 PM
Alternator replacement on 2007 Yaris Slipangle DIY / Maintenance / Service 4 07-10-2012 10:38 AM
2 bolt alternator, lower pivot bolt jstantherprsn DIY / Maintenance / Service 7 04-12-2011 10:02 AM
bottom long bolt for alternator yaris9876 DIY / Maintenance / Service 5 05-24-2010 02:02 PM
