01-13-2015, 06:09 AM | #1 |
Drives: Yaris 2001 Join Date: Jan 2015
Yaris 2001 The engine yellow/orange warning light in the dashboard
Hi all hope someone can help
I by mistake put 1L of home heating oil in the car use the wrong pump at the station. I was told at the time just to fill the car and it would run out though the engine. But now i have a problem with the warning light and the car is chugging in first and second and when the car is sitting in neutral. I have changed the air filter and spark plugs and later today i will do a oil change. If anyone else has any other ideas on stopping the chugging or will i have to take it to a garage. thanks Colin |
01-13-2015, 06:14 AM | #2 |
Drives: 09 5dr LB, 2x 08 3dr LB Join Date: Oct 2008
Keep topping up the tank with petrol. You also may need to do a good cleaning of the fuel system.
You can try adding fuel system cleaner to the tank, but you may have to replace the fuel filter (which is in the tank) and may have to have the injectors properly cleaned. In the meantime just keep diluting it by keeping the tank full. The engine light is likely on due to misfiring from the plugs fouling.
01-13-2015, 11:31 AM | #3 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
let it run through and keep adding gas as Scott said. Once you think it is no longer in the tank than see how the car is running. If problems arise than you can fix them as they are. The fuel pump/screen may need to be replaced but they also ay not so your best bet would be to wait and find out.
01-14-2015, 04:44 AM | #4 |
Thanks Guys, for you help. Is it hard to clean the injectors or will i have to take it to a mechanic. Also would i be able to change the Petrol Filter and if so where is it. Was told it under the back seat? or would i have to get a Mechanic to do that do just dont want to spend big $$$£$£$$££$ for someone doing it
thanks Colin |
01-14-2015, 06:21 AM | #5 | |
For the filter you do have to get into the tank, which is under the back seat.
01-14-2015, 06:52 AM | #6 |
Thanks for you help. i will put in a cleaning solution and will try and change the fuel filter.. any tips on replaing the petrol filter
thanks |
01-14-2015, 06:57 AM | #7 |
Sorry one last question if all this fixes the problem will the warning light go off itself or will it have to be reset?
thanks again Colin |
01-14-2015, 01:12 PM | #8 |
You can reset it yourself by disconnecting the battery for a minute. It may self clear before that, depending on the code.
01-14-2015, 09:35 PM | #9 |
01-14-2015, 10:45 PM | #10 |
I am not sure if seafoam is sold over there. Any Techron based cleanser would be fine or the Lucas products.
01-15-2015, 09:47 AM | #11 |
Seafoam seems a bit on the strong side for me. Unless it's an old car I would tend to stay away as I would be worried about seals etc. Keep in mind I have no evidence of this, more or less following the precautionary principle.
I'd use a lighter fuel injector cleaner and let the fuel run through and see if it clears itself. If the CEL no longer illuminates than it's likely clean and good to go. If the CEL lights up again consistently after a few new tanks of gas, than I'd probably think of something like SeaFoam |
01-16-2015, 06:53 AM | #12 |
Thanks Guys i will let you know how i get on. I have full the tank with petrol and added Redex Petrol Injector Cleaner so hoping that will sort it out
thanks Colin |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
NEWS: TOYOTA REVEALS ALL-NEW YARIS SEDAN AT 2006 LOS ANGELES AUTO SHOW | VitzBoy | General Yaris / Vitz Discussion | 7 | 09-20-2023 07:50 AM |
Yaris Verso dash vs Yaris dashboard | janos | DIY / Maintenance / Service | 0 | 10-26-2014 03:52 AM |
SRS warning light, pass. seatbelt light, pass. airbag light PROBLEMS! | tylerwatts53 | DIY / Maintenance / Service | 1 | 07-17-2014 08:53 AM |
06-10 Yaris Sedan cold air intake $40 | kylevh21 | Items for Sale by private party | 2 | 04-01-2012 02:14 PM |
2007 Yaris Pricing Info ! | YarisBueller | New YARIS Purchase Forum | 104 | 06-24-2009 04:54 PM |
